Thread: Pan Joist Problem
    2006-10
    Dallas, Texas, USA
    4
    Default Pan Joist Problem
    I need to make a variable with Pan Joist Beam. I have a pan joist system on a radius of a building. The Pan Joist are parallel to an interior beam. The main beam between columns need to be a certain width at the interior column and wider at the outer column. I have found no way to do this. Any suggestions. I have tried to modify the Pan Joist family, but it appears that you can not do a blend in a beam type. Any help is appreciated. I can send the model th anyone who would like to see the issue.
    100 Club troberts's Avatar
    167
    Cool Re: Pan Joist Problem
    Quote Originally Posted by kbillings.124735 View Post
    I'm not sure, but wouldn't it be easier to model the slab at it's total thickness, say 16".
    Then model the pans as what they really are - Voids. Space the voids just as you do pans. What is left will be your beams and joists. And they can taper.
  1. Exporting existing joist - joist material to blame?
    By BecFra in forum Revit Structure - General
    Last Post: 2009-01-28, 07:17 PM
  2. Exporting existing joist - joist material to blame?
    By BecFra in forum Revit - Platform
    Last Post: 2009-01-28, 05:47 PM
  3. ABS Joist Display Problem
    By thomas.stright in forum AMEP General
    Last Post: 2007-06-06, 07:29 PM
  4. Joist Length Problem
    By mikemck in forum Revit Architecture - General
    Last Post: 2006-10-09, 03:08 AM
  5. Problem w/ Roof / Joist interaction.
    By bclarch in forum Revit Architecture - General
    Last Post: 2003-07-16, 06:27 PM
