Thread: Hidden dashed line not showing up in paperspace
    2009-02
    0 Did you find this post helpful? Yes
    Red face Hidden dashed line not showing up in paperspace
    Hi there,
    I am trying to plot a demolition plan with the dashed lines. The lines show up dashed in my modelspace, however, when I switch over to layout to plot it, my dashed lines do not show up. Any ideas or suggestions as to what I can do to fix it?
    -Thanks! : )
    2003-10
    San Francisco CA
    1,190
    Default Re: Hidden dashed line not showing up in paperspace
    Hi Suzyq,
    First, Welcome to AUGI and congrats on your first post
    Do the lines show up at all? If they do then it's probably the LTSCALE or PSLTSCALE setting. These control scale of dashed lines. Personally I set both of these at 1 which uses the plot scale in paperspace to determine the linetype spacing.
    If the lines are not showing up at all check to see if the layer has been turned off in the viewport.
    Hope this helps,
    Last edited by stelthorst; 2009-03-04 at 09:45 PM. Reason: Corrected variable spelling
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    I could stop if I wanted to sschwartz's Avatar
    2005-04
    Oakland County, Michigan
    424
    Quote Originally Posted by stelthorst View Post
    Hi Suzyq,
    Do the lines show up at all? If they do then it's probably the LTSCALE or PLTSCATE setting. These control scale of dashed lines. Personally I set both of these at 1 which uses the plot scale in paperspace to determine the linetype spacing.
    Hope this helps,
    If that doesn't work try setting your MSLTSCALE to 1?
  1. Duct center lines showing in Hidden Line
    By SwartzieCRA in forum Revit MEP - General
    Last Post: 2012-04-26, 10:41 PM
  2. hidden lines showing as dashed lines
    By tomcarver in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-09-26, 09:09 AM
  3. Replies: 3
    Last Post: 2007-03-25, 02:19 PM
  4. Hidden/Dashed Line Types & Linetype scales
    By scompton in forum ACA General
    Last Post: 2007-01-16, 03:14 PM
  5. not showing hidden line in hidden mode
    By Cheuk Ling in forum Revit Structure - General
    Last Post: 2006-06-09, 12:48 PM
