Thread: ‘Invisible’ lines in Revit
    2005-04
    230
    Default ‘Invisible’ lines in Revit
    Hi there
    What is the procedure when hiding a join between two objects? i.e. The line created between a floor slab and a wall? (See attached) Is there a way to draw a model line that is ‘invisible’ which then hides this joint?
    Thanks any advice would be greatly appreciated.
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,081
    Default Re: ‘Invisible’ lines in Revit
    You can try using the "join geometry" command on the toolbars. The other option would be to use the "linework" tool and apply invisible lines to the edges. This option is view spscific while the "join geometry" option will fix the issue in all view where you see the problem.
    ______________________________________________
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    2005-04
    230
    Hi Jeff
    Thanks for the response! The "join geometry" command works great between walls and floors. What does one do when trying to join say the underside of a stair to a wall? Is this when you would use the "linework" tool? As you mentioned this is only view specific! Is there a way of drawing an invisible line which is invisible in all views?
    Thanks again
    2004-06
    Memphis TN area
    6,701
    Quote Originally Posted by craighowie View Post
    Hi Jeff
    Thanks again
    Unfortunately stairs cannot be joined to other geometry. This has been a wish list item for some years now. There is no solution that will be applied to all views. Linework is probably your best choice.
    AERC, PLLC
    Hernando, Mississippi
    I could stop if I wanted to nsinha73's Avatar
    2006-09
    CA
    460
    Make sure you have same materials and in "Course" detail display...
    The Course, Medium and fine also affects what you are trying to achieve...
    It is much easier to be an Obstacle in Revit then a Resource.
  1. Invisible Lines For Door
    By SCOWBOY74 in forum Revit Architecture - Families
    Last Post: 2011-06-23, 04:34 PM
  2. Invisible Lines...
    By mdcoop_ak in forum Revit Architecture - General
    Last Post: 2008-02-04, 11:49 AM
  3. How to remove invisible lines?
    By tomm in forum Revit Architecture - General
    Last Post: 2005-04-19, 08:42 PM
  4. AAAARRRRRGGGGGHHHH! 7.0 & Invisible Lines
    By christo4robin in forum Revit Architecture - Families
    Last Post: 2004-11-29, 04:36 AM
  5. Invisible Lines
    By cphubb in forum Revit Architecture - General
    Last Post: 2004-08-17, 07:53 AM
