Thread: Masking Region line "snap"?
    2009-03
    14
    Default Masking Region line "snap"?
    I have a family with a masking region, the outline of which is visible. When I load the family into my project, I want to be able to "snap" or "align" to the edge of my masking region. However, the edges will not highlight when my cursor hovers over the edge. I know i could solve this simply by creating reference planes or lines at the edge of my masking region, but it seems like a workaround. Is there another way?
    2004-06
    Memphis TN area
    6,701
    Default Re: Masking Region line "snap"?
    Quote Originally Posted by jo_3_ View Post
    I'm pretty sure that only reference planes/lines are available to use for aligning objects placed in projects. So no it's not really a workaround.
    AERC, PLLC
    Hernando, Mississippi
    2009-03
    14
    Thanks, Patrick. The reason I felt like it was "cheating" is because I have other symbolic lines in the family (of the same line type that I'm using around my masking region) to which I can snap/align/dimension. It seems like it just doesn't work when it's part of the masking region.
    That said, I tried outlining the masking region in the family editor with both reference lines and reference planes; I can only get the edges to snap when I use the planes. Perhaps I'm doing something incorrectly, but since the planes work, I'm satisfied.
    Thanks again.
    All AUGI, all the time Katika's Avatar
    2004-07
    Perth Australia
    736
    I have successfully used invisible lines in families to snap to. (on annotations where you cannot draw a reference plane)
    It may be a case of not being able to snap to the model edges, but if you have a line or ref plane aligned to the edge than you can.
    I agree that it is a bit quirky.
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
  1. Families with Masking Regions, "Overlapping"
    By saeborne in forum Revit Architecture - General
    Last Post: 2009-06-12, 08:30 PM
  2. Formula Array "Snap" to a given size?
    By jsteinhauer in forum Revit Architecture - Families
    Last Post: 2008-04-04, 05:51 AM
  3. Replies: 8
    Last Post: 2006-02-07, 02:35 PM
  4. Can't get stretchable instance parameters to "snap"...
    By iru69 in forum Revit Architecture - Families
    Last Post: 2005-10-20, 08:53 AM
