Any idea why my hidden lines are not showing up in plan?
Looked at the line styles and everything looks like its working but the lines are still solid?!?!?
Martin Figlarz
CAD/BIM Manager
We are hiring please visit:
http://www.ipsdb.com/careers/job-postings
what is your drawing scale set to? Also check your object styles overrides and your VG model overrides for ducts.
Your Content Your Way - http://bit.ly/11duMUO
Steve Germano
www.INVIEWlabs.com
INVIEW labs blog - http://www.inviewlabs.com/Blog/inviewblog.aspx
Tweeps - https://twitter.com/SG_MontanaBound
scale is set to 1/4" but I did try 1/8" and it changed a little .... are the object style lines set right???
Also I did try changing the Mech Hidden line pattern to all the different line scales with little or no change... I even tried dashed line pattern and it didn't make any difference?!?!?
Am I missing something?
(I was missing something.... the view range needed to be moved up higher)
still a little confused but whatever
Martin Figlarz
CAD/BIM Manager
It looks like you have NEW duct over EXISTING duct. If this is the case you need to have no overrides on your Existing line projection/surface pattern.
