Results 1 to 9 of 9
Thread: Structural Usage
    2007-04
    2
    Angry Structural Usage
    I hope someone knows of a add-on or some other way to ADD types to the structural usage types! I need to break out the building in more ways then girders, purlins, joist, other, and hor bracing...
    Thanks
    2008-04
    269
    Default Re: Structural Usage
    We have the same problem over here. The Structural Usage is "hard wired" into the system, and as far as I am aware there is no way to add more option.
    Try submitting this request on the wish list.....?
    Regards
    Regards
    Glenn
    Check out my blog - http://revitst.blogspot.com/
    Português - Revit Moderator fernando's Avatar
    2003-11
    Leiria - Portugal
    325
    "break out the building in more ways then girders, purlins, joist, other, and hor bracing... "
    What you mean with that?
    Why more categories?
    2008-12
    16
    Quote Originally Posted by fernando View Post
    Why not have more categories? I for one would like to see more options, "girt" is the first one that comes to mind. IMO by having an "other" catagory in the first place they are clearly admitting that their list is not all encompassing and more options are needed. If they had a comprehensive list of options there would be no need for an "other" catagory.
    2008-06
    Sunshine Coast, QLD
    40
    I've added a shared parameter available to columns and framing (and a bunch of other stuff, actually). Just a simple text parameter called Member Usage (type, not instance). Amongst other things, I use this to get around the limited amount of framing categories.
    For example, I have it set to STRUT in my CHS framing families, as that's mostly what I use them for (of course it can be changed as needed). I also have a filter that is basically Framing->Member Usage=STRUT. I can add that filter to my framing layouts to change the way the struts are displayed, regardless of what structural usage category they are (I just set them to girder), or turn them off using the same filter for things like purlin layouts.
    That parameter can also be used in schedules to sort, group and filter whatever members I want, how I want them.
    The only thing it doesn't really replicate is the fact the built-in categories have a default material associated with it, but I haven't found that to be a limitation, given the multitude of ways to set materials on objects.
    2006-05
    835
    FOUNDATION!!!!
    The amount of times my raft beams come up as "issues" in Revit when checking members for analytical consistency.
    AJS
    BIMM Consultant
    www.GHD.com
    2006-09
    442
    We have done something similar, we added a shared parameter called "function as". Where we can seperate lateral braces from truss braces, and truss chords from framing members. We also stared added a parameter called "design by" were the user input the initial of the person that is designing that member. This way we set up filter and quickly see what members were designed by who. It also helped when linking with ram steel, to ensure that ram didn't overwrite something that was being designed by someone else.
    2006-09
    255
    Hi
    This shared parameter/filter sounds interesting.
    Could this technique be used to change the way vertical bracing is displayed in plan?
    I want to display the main framing in fine detail but still have the bracing show as it would be in course ie a single line.
    With them both shown in full the detail looks very cluttered.
    I hope this is the case
    Cheers
    Dave F.
    AutoCAD 2012 Structural Detailing SP1 & Revit Structure 2012 32bit
    Win 7 32bit
    2008-06
    Sunshine Coast, QLD
    40
    Detail level can only be set by view or category, not by subcategory or filters. So to do what you are asking I guess you would need a specific family for your bracing member that had its visibility set to display a model line in fine instead of the sweep/extrusion in plan/rcp views (don't think symbolic lines would work as chances are the view wouldn't be parallel to the beam, being a brace).
    I could be entirely wrong about all this too, of course
  1. Structural usage - Non-bearing structural walls
    By Bryan Thatcher in forum Revit Structure - General
    Last Post: 2010-08-26, 07:51 PM
  2. Structural Framing - Structural Usage
    By Davied2 in forum Revit Architecture - General
    Last Post: 2010-04-07, 08:45 AM
  3. Structural Usage
    By Tim Bosman in forum Revit Structure - General
    Last Post: 2009-08-13, 10:56 PM
  4. Floor - Structural Usage
    By captainbunsaver in forum Revit Architecture - General
    Last Post: 2006-05-09, 04:33 PM
  5. Structural Usage
    By Tobie in forum Revit Architecture - General
    Last Post: 2005-01-11, 10:27 PM
