Results 1 to 8 of 8
Thread: Excel connection
    2002-05
    47
    Default Excel connection
    Hi,
    Having written vba codes for AutoCad 2005 and Inventor 9 that connects to Excel and put some title block entries into same workbook, some strange problems occur.
    Although running fine separately in each application, I cannot run in the other. That is: If I open AutoCad and Inventor, run the AutoCad code (works fine), then a following run of the Inventor code fails - and vise versa (I have tried every combination of open/run). It is as the first takes over Excel and won't let the other in.
    I use the ExcelLink method of connecting and closing Excel.10 for every run.
    Help is needed...
    Best regards
    Claus
    Turlock, CA
    6,419
    Default Re: Excel connection
    Can you show the code you are using to connect/disconnect?
    C:> ED WORKING....
    LinkedIn
    100 Club mtuersley's Avatar
    2001-12
    122
    Quote Originally Posted by eljobe
    Thats the problem If he is using the Autodesk ExcelLink as an example, it doesn't clear out any of the objects it substantiates.
    Set all your Excel objects to Nothing beginning with the most insignificant and work your way back out through the worksheet object then finally the app object. Failing to clear sub objects of the app, will not free up the app.
    Read my article on data access [www.cadalyst.com] as you are better off using an ODBC connection to the XLS file than opening the entire Excel application.
    2002-05
    47
    Thanks both,
    The connecting code is the following:
    Public Sub ConnectExcel(X As Variant)
        ' X is only used to suppress this routine from the Run Macro Dialog
        ' Determine the versions Excel that we have available on this machine,
        ' and set the public variables accordingly
        On Error Resume Next
        ExcelVer = 0
        ' Try to find a version of Excel 10
        ' Attempt to activate an existing instance
        Err.Clear
        Set ExcelServer = GetObject(, "Excel.Application.10")
        If Err.Number = 0 Then
            ExcelVer = 10
            GoTo FINISH
        End If
        ' Create a new instance
        Err.Clear
        Set ExcelServer = CreateObject("Excel.Application.10")
            ExcelVer = 10
            GoTo FINISH
        End If
    FINISH:
        ' If we don't have Excel installed, refuse to run
        If (ExcelVer = 0) Then
            MsgBox "ExcelXP skal være installeret for at bruge denne metode", vbCritical, conDemoName
            ExelLink.Hide
        End If
        ExcelServer.WindowState = -4140 ' xlMinimized
        ExcelServer.Visible = True  ' Make it visible
    End Sub
    In between objWorksheet and objWorkbook is set:
    Set objWorkBook = ExcelServer.Workbooks.Open("Path")
    Set objWorksheet = objWorkBook.Sheets(1),
    where Path is the path to my Excel workbook
    The disconnecting code:
    Set objWorksheet = Nothing
    Set objWorkBook = Nothing
    Set ExcelServer = Nothing
    ' close Excel
        Dim excelApp As Excel.Application
    Err.Clear
        Set excelApp = GetObject(, "Excel.Application.10")
        If Err <> 0 Then
            Err.Clear
            MsgBox "Excel er ikke aktiv.", vbExclamation
        Else
            excelApp.DisplayAlerts = False
            excelApp.Quit
        End If
    Exit Sub
    _______________________________________________
    To mtuersley:
    Excellink says about the code:
    ' Some of this code is not the way we would ordinarily
    ' write it within Excel. However, we need to work around
    ' a pair of Excel anomalies. If we refer to the Range
    ' object, or use the With/End With construction, it turns
    ' out that Excel does not remove itself from RAM when closed.
    I will study your article
    Thanks again
    Claus
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    Last edited by Opie; 2006-10-27 at 02:15 PM. Reason: [CODE] tags added, see Moderator Action
    2001-12
    122
    Quote Originally Posted by cll
    ' close Excel
    Err.Clear
    If Err <> 0 Then
    Err.Clear
    Else
    excelApp.Quit
    End If
    Exit Sub
    Is it a typo that you have the connection code within the disconnect code? The disconnect should just be:
    If Not objWorksheet Is Nothing Then Set objWorksheet = Nothing
    If Not objWorkBook Is Nothing Then Set objWorkBook = Nothing
    If Not ExcelServer Is Nothing Then Set ExcelServer = Nothing
    If Not excelApp Is Nothing Then Set excelApp = Nothing
    Also why are you using two Excel App objects?
    To mtuersley:
    Especially if they never close out their references to Excel objects. I've used both and there is no problem with Excel closing [maybe back in pre2000]. But I also rarely use Excel itself since I opt for the ODBC connection.
    Good Luck,
    Mike
    2002-05
    47
    Ok - I can't give a good answer to your questings (but must be due to my insufficiency to vba).
    I've tried your suggestions without much result, but found out that a little End before leaving the code solved the problem ??
    Thanks again!
    Claus
    2006-03
    11
    Quote Originally Posted by mtuersley
    ....Read my article on data access [www.cadalyst.com] as you are better off using an ODBC connection to the XLS file than opening the entire Excel application.
    Any ideas on where i could find this article? I tired searchin Cadalyst with no luck
    thanks
    Brett
    Turlock, CA
    6,419
    I couldn't find it either. Just ask Mike. Click on his name in this thread and send him an email.
    C:> ED WORKING....
    LinkedIn
  1. Connection database with Excel and Autocad
    By luislhss in forum VBA/COM Interop
    Last Post: 2020-05-15, 06:40 PM
  2. 2014: HSS- W connection + Plates, How to model this special connection?
    By jiangrayrui376960 in forum AutoCAD Structural Detailing
    Last Post: 2013-05-02, 10:01 PM
  3. MAKE BOLTED CONNECTION GENERATOR REMEMBER MATERIAL OF PLACED CONNECTION
    Last Post: 2012-07-02, 10:13 PM
  4. Replies: 1
    Last Post: 2009-04-29, 11:03 AM
  5. C3D Table connection with Excel
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-05-01, 08:53 PM
