Results 1 to 10 of 20
Thread: Excel Table to AutoCAD Table.
    2006-01
    Manchester,England, UK
    165
    Default Excel Table to AutoCAD Table.
    Is it possible to insert a excel table into AutoCAD then convert it into an AutoCAD table format?
    Gareth Spencer
    AutoCAD-AutoCAD LT-AutoCAD Civil 3D-AutoCAD Structural Detailing-Revit Structure-Revit MEP
    http://becadsmart.blogspot.com/
    http://www.linkedin.com/pub/gareth-spencer/32/25/842
    Twitter: @becadsmart (Personal) @Garethcadline (Work)
    All AUGI, all the time Capt. Computer Crasher's Avatar
    2006-12
    South of North & East of West
    786
    Default Re: Excel Table to AutoCAD Table.
    Quote Originally Posted by Spenner View Post
    Yes. Using AutoCAD 2006 or above.
    1) Open the Excel file and Highlight all cells you want for the table.
    2) Right-click and pick copy. Collapse Excel.
    3) Open the AutoCAD drawing you want the table in.
    4) At the Top AutoCAD menu under EDIT pick PASTE SPECIAL
    5) At the paste special window make paste is mark and
    pick AUTOCAD ENTITIES and hit OK
    6) Pick an insert point.
    Have your table style you want set to current when to insert the table or change it later.
    2006-01
    165
    Smile Re: Excel Table to AutoCAD Table.
    Beltin.
    Thanks for this Capt Computer Crasher..
    Gareth Spencer
    2005-12
    3
    When you start the table command, look in the upper right corner of the dialog box, under insert options pick "from data link" instead of "start from empty table". Then "create new data link" and follow the data link manager. It will give more options on how you want the data to stay in ACAD - just the text added to the table, a maintained link between the Excel file and the dwg, etc...
    You can also extract data from the current dwg to Excel, like getting an inventory of your blocks. As more blocks are added to the dwg, then saved the Excel file will update.
    2006-12
    786
    Quote Originally Posted by anna.cummings View Post
    the OP was operating in AutoCAD2007 which does not have the data link option.
    2006-01
    165
    Quote Originally Posted by Capt. Computer Crasher View Post
    What versions does it work in?
    Gareth Spencer
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    Data linking was introduced in AutoCAD 2008.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2009-04
    7
    Does anyone know why the 16th table locks up the program?
    2006-12
    786
    Quote Originally Posted by Lorraine.McNulty View Post
    Which version are you using and which service pack? also are you using copy/paste to add the datalinks or the data link option from the table command.
    if you are using copy/paste try using the data-link option from the table command.
    2009-04
    7
    CIVIL 3D 2008.......All service packs are automatically installed by IT
  1. Trouble with Excel Information to AutoCAD Table
    By CADdancer in forum AutoCAD Tables
    Last Post: 2010-09-08, 08:21 PM
  2. Replies: 9
    Last Post: 2010-05-03, 09:19 PM
  3. How to import excel table to autocad
    By mandy in forum AutoCAD General
    Last Post: 2008-10-31, 06:32 PM
  4. Need Help, Trying to use excel formulas in AutoCAD Table
    By ReachAndre in forum AutoCAD General
    Last Post: 2008-08-04, 02:45 PM
  5. AutoCAD 2007 - Excel to Table, best working method
    By david.scheu in forum AutoCAD General
    Last Post: 2006-08-25, 01:01 AM
