Thread: Error [1200.5.-96]
    2003-11
    Question Error [1200.5.-96]
    the network license manager was not able to get a valid license. If this problem continues, please contact your system administrator
    Error [1200.5.-96]
    help me please
    2001-10
    Arizona
    2,337
    Default Re: Error [1200.5.-96]
    This is most likely your problem/solution
    This error message is from the Autodesk® License Manager (AdLM); it indicates the license server either has not been started, or is not properly configured.
    To resolve this problem, work through the following troubleshooting suggestions:
    * Properly configure the FLEXlm® service
    * Start the license server.
    * Review the license file contents for any corruption or incorrect server information.
    * Check the status of the license server to ensure that the AdLM has started. If the AdLM has started, a line similar to the following is displayed at the bottom of the status inquiry results (in the LMTOOLS dialog box, Server Status tab, click Status Inquiry):
    This should return the license server status.
    At the vary least performing these steps will verify that the license server is UP
    and functioning correctly. While there verify that it is configured to run as a SERVICE.
    Also verify through the status report that you are not requesting more licenses than you
    have.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2001-05
    Austin, TX USA
    2,201
    Check out this link: Raster Design Network install. The last post should be of interest if you are using Windows XP with SP2.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    Active Member tomdillenbeck's Avatar
    2004-05
    Dearborn, MI
    52
    Unhappy Re: Error [1200.5.-96]
    Help.
    I work from home on weekends with a checked out license on my laptop. Sometimes 2009 works fine, but then eventually it hits this error message when opening and there's no fixing it. I have adjusted my flexlm time setting up to 6000000 or 6 secs and that hasn't helped either - although it seemed to help to increase it at the office.
    Any thoughts for checked-out applications?
  1. проектирование схемы с ПЛК siemans s7-1200
    By nae937091 in forum Русский - AutoCAD Electrical
    Last Post: 2011-05-19, 01:02 PM
  2. Replies: 0
    Last Post: 2011-03-17, 06:54 PM
  3. HP 1200 plotter - custom paper size
    By ralph.pluckrose in forum Hardware
    Last Post: 2010-05-25, 02:37 PM
  4. 1200 new families on Autodesk Seek
    By still.james in forum Revit Architecture - General
    Last Post: 2008-08-20, 01:46 AM
  5. Replies: 2
    Last Post: 2007-03-02, 07:57 PM
