Thread: FATAL ERROR OPENING .DWG FILE
    2009-03
    Exclamation FATAL ERROR OPENING .DWG FILE
    I encountered fatal error when opening .dwg file. I tried to recover/repair the same .dwg file but same thing happened, I cannot open the file anymore. When I search where it is autosaved, the folder local~/temp~ i cannot find in my system. Please help me. Thanks
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Default Re: FATAL ERROR OPENING .DWG FILE
    Welcome to AUGI, and congrats on your 1st post. Unfortunately this is possibly a very difficult thing to do. It depends on what's happened with the DWG.
    Is there a BAK file in the same folder as the DWG? If so rename it to a DWG (with a different name from the original) and try opening this. If still a prob, try recovering this.
    BTW, what size is the DWG file? If zero there was probably a hard-disk crash during save ... which is nearly impossible to rectify
    If all else fails, try getting an undelete utility from the web. There are numerous available, just do a Google search. One I sometimes use is Undelete Plus. Basically it scans your hard drive for any deleted files (including those AutoSaves which sometimes disappear). As long as no new file was saved over the same space as the deleted file, it should be able to restore it.
  1. 2014: Civil 3d Fatal Error opening drawings
    By JOROB26 in forum Civil 3D - Civil Design Companion - General
    Last Post: 2014-03-05, 02:00 PM
  2. Fatal Error opening Design Center (ADCENTER)
    By rwingender in forum AutoCAD Map 3D - General
    Last Post: 2012-01-19, 07:12 PM
  3. In-place family with opening cut - first fatal error in a LONG time
    Last Post: 2010-04-08, 07:09 PM
  4. FATAL ERROR every time when Opening a certain drawing file
    By randyspear in forum AutoCAD General
    Last Post: 2006-05-08, 12:58 PM
