While trying to create pdf's of a job, all but two sheets worked perfectly.. After much head scratching as to why.. I finally realized it was that these two sheets had polyagonal viewports instead of the standard rectangle viewport.. When these viewports are deleted the pdf works fine.. if left on .. the plot comes out as only a portion of the sheet.. which by the way does not follow in any way the size or shape of the offending viewport.
Has anyone else had this happen? If so.. is there a fix? A different setting perhaps..
Thank you in advance for your help..
I am using Adobe 6.0
sharon olsen
bna consulting engineers
