Results 1 to 6 of 6
Thread: Panel board 'Mains' colloquism?
    2008-06
    Adelaide, South Australia
    279
    Default Panel board 'Mains' colloquism?
    We can't figure out what 'Mains' is referring to in the panel board settings. Does it refer to the 'Main switch', 'Busbar', or 'Circuit breaker'?
    From Australia BTW.
    I could stop if I wanted to dmb.100468's Avatar
    2005-11
    Virginia
    222
    Default Re: Panel board 'Mains' colloquism?
    My guess would be it refers to the Main Circuit Breaker, but then if you use a Main Lug Only panel you cannot leave the parameter blank, which is annoying.
    2008-06
    279
    So basically we have a parameter that I assume is used on all panel boards, and yet no one knows what it's actually referring to??
    2009-02
    Houston
    686
    "Mains" refers to the rating of the mains feeding the panel. - From the RME User's Guide
    Maybe that doesn't help...
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    889
    So where are you "supposed" to put the MCB if there is one? Modifications I guess?
    I think one of the problems with panel schedules is that the panel itself has some very odd functionality. The panel itself feels too disassociated with the model in that everything needs to be set manually as just a text box.
    It would be nice if you could set nominal breaker and bus sizes and have the program do a quick calc based upon the load to set that. It would obviously have to be overrideable though.
    2008-06
    279
    We've decided to use the 'Main' field for 'Main Switch' which is the main isolating switch. Hopefully this won't cause any problems with circuiting and things like that.
  1. Aide lave-mains !
    By dume.susini in forum Revit Architecture - Familles
    Last Post: 2011-11-10, 11:00 AM
  2. electrical panel board created but shown none
    By revit_wannabe in forum Revit MEP - General
    Last Post: 2009-05-05, 04:59 PM
  3. Panel board reassigning circuts
    By troy.crandell635379 in forum Revit MEP - General
    Last Post: 2009-04-20, 05:15 PM
  4. Distribution Board (Panel Board) Symbol
    By schrodingerscat in forum Revit MEP - Families
    Last Post: 2008-10-01, 01:29 AM
  5. Fire mains, Dry Riser - sizing?
    By Elrond in forum Revit - In Practice
    Last Post: 2005-06-10, 03:55 PM
