Thread: Bad Argument
    2001-11
    236
    Default Bad Argument
    I have the following errors after opening AutoCAD 2009.
    How can I locate the files which has the errors?
    Windows Explorer could not locate the word "lentityp nil" or "stringp nil" with the the "A word or phrase in the file" option.
    ERRORS:
    AutoCAD menu utilities loaded.; error: bad argument type: stringp nil
    AutoCAD menu utilities loaded.Loaded...; error: bad argument type: lentityp nil
    2004-08
    Iron Station, NC
    3,198
    Default Re: Bad Argument
    Quote Originally Posted by omorah View Post
    ERRORS:
    you wont find those lines within a file, they are error codes, it means:
    ((= ErrorMsg$ "bad argument type: stringp nil") "String variable not defined.")
    ((= ErrorMsg$ "bad argument type: lentityp nil") "entget passed a nil.")
    meaning you have some sort of a custom routine that is being loaded that is not coded properly, or not being called properly. the only way to really figure it out is to load your custom routines one at a time and trace the error. At our offices, I added print lines to the startup routines that allow me to determine where in the order our startup failed. It adds a lot of extra text to the startup, but it makes it a heck of a lot easier to troubleshoot.
    2002-12
    77
    One of the things that I did here (at work) was to add to line to all of out major lisps (acad.lsp, acaddoc.lsp, company.lsp as well as any .mnl)
    (princ "\n Loading xxxx.lsp") at the begining
    (princ "\n xxx.lsp loaded succefully....") at the very end
    This way I can tell were in the load process I get a failure. This allow me to track it from there.
  1. Help with Defun Argument
    By jeff.richards in forum AutoLISP
    Last Post: 2011-08-03, 04:23 PM
  2. error: bad argument value: positive 0
    By marijan.marsic in forum AutoLISP
    Last Post: 2010-05-06, 01:24 PM
  3. bad argument type: lentityp nil
    By moshira_hassan in forum AutoCAD General
    Last Post: 2009-04-15, 07:09 AM
  4. Presentation Argument
    By mjdanowski in forum Revit MEP - General
    Last Post: 2007-12-04, 02:22 PM
  5. bad argument type: FILE nil, help plz
    By jgroh in forum AutoLISP
    Last Post: 2007-10-30, 01:15 PM
