Help....everytime I run a specific lisp my duoble-click is deactivated for switching between MSPACE/PSPACE. And DBLCLKEDIT is set to 1.
Take a look a the system variable SPACESWITCH
If it is set to 0 you cannot double click into a viewport. If it is set to 1 you can double click into a viewport.
Maybe your lisp is setting Spaceswitch=0 and not resetting it to 1 (poor error handling?)
Well, I figured out what was causing the issue, but I'm not sure why. I was using TEXTTOFRONT. After removing it from my lisp the issue went away. Not sure why that would affect SPACESWITCH.
I know that this is an old post but here is another fix for this problem, which I have finally found:
- In the current drawing type in SIGVALIDATE, you will then get a message stating that the file will be updated on the next save.
- Next close and save the file.
- Next re-open the file and you will notice that there will now be a new icon at the lower right hand corner of the ADT command line. This is a small dwg icon with a green check mark, meaning that it is now a "trusted" AutoCAD drawing.
Now you since the file is "Trusted" you can activate and double-click Viewports as normal.
Best Regards
Ken Murphy
Ken Murphy
Application Support Specialist, Design Technology Services
NELSON
222-30 Walnut Street
Philadelphia, PA 19106
