Thread: Ability to detach objects from Mass, which were created from faces of Mass objects
    Wish List Administration
    2007-08
    603
    Default Ability to detach objects from Mass, which were created from faces of Mass objects
    Summary: After creating objects such as curtainwalls and roofs from faces of mass objects, "detach" them, and then use "normal" editing tools--instead of having to edit the Mass and "re-create" each time an edit is required.
    Description: Ability to detach objects from Mass, which were created from faces of Mass objects.
    How Used: After creating objects such as curtainwalls and roofs from faces of mass objects, "detach" them, and then use "normal" editing tools--instead of having to edit the Mass and "re-create" each time an edit is required.
    Feature Affinity: Autodesk Building Maker (Massing)
    Submitted By: Cliff Collins on September 29, 2008
    2006-02
    High River, Alberta, Canada
    8
    Default Re: Ability to detach objects from Mass, which were created from faces of Mass objects
    Agreed! A very useful feature!
  1. families and mass objects
    By jacek.brzezowski in forum Revit - Platform
    Last Post: 2008-09-24, 11:41 AM
  2. Mass objects & AEC Walls
    By .chad in forum ACA General
    Last Post: 2007-05-22, 01:51 PM
  3. Mass Objects - How do I change the Colors?
    By saeborne in forum Revit Architecture - General
    Last Post: 2007-02-13, 04:49 PM
  4. Mass Objects
    By raddis in forum Revit Architecture - General
    Last Post: 2006-05-31, 02:28 AM
  5. Colouring Mass objects
    By Merlin in forum Revit Architecture - General
    Last Post: 2004-10-01, 06:46 PM
