Is there a way to do this?
I want to edit the .rft files in the library to contain our standard office object styles (i.e. giving the detail component .rft a lineweight 1 through 9 instead of Thin, Medium, and Heavy).
Thanks!
Thanks!
I'm pretty sure you can open as a family from the original template, save it as a family after you modify it, then rename it ti an rft.
Kathy Taylor
Senior Structural Draftsperson & Proprietor
TaylorCAD
www.taylorcad.com.au
I don't suffer from insanity - I enjoy it!
Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
heh, I was just repeating something I read on here ages ago
The only one I changed I think was a generic annotation, mostly cause I got sick of changing the default font name and size.
It is possible that the template loses something when creating the family, I'll have to investigate that when I get time, unless of course the upcoming release actually allows for template saving.
Kathy Taylor
TaylorCAD
Kathy
This is a Revit 2009 Bug! in 2008 - you could open up the Template & then do a Saveas ontop of itself - rft was on the Drop down list of the Saveas dialog box. In 2009 the factory removed this option - Who knows why is anybodies guess. Hopefully they have restored it in 2010 as it is a real pain to have to do it manually in Windows Explorer!
Just tried doing this in Reft 2010, and you you still cannot open an .rft file. I did the method explained here, but when added the .rft on the file in the windows explorer it did not modify the file type, so I cannot create a family from the modified template. Anyone know what I'm doing wrong?
You probably have Windows Explorer set to not show File Extensions, so you are adding the .rft to the file name. Go in your settings for Windows explorer (Tools > Folder Options > View) and UNCHECK the box for "Hide common file type extensions."
This assumes you have permission to touch, lol...
Revit 2011, still have to follow this procedure. Anyone know if 2012 let's you make your own family templates WITHOUT this obnoxious workaround?
Revit 2012, obnoxious workaround still in force...
