Results 1 to 7 of 7
Thread: Copy schedule data from one revit schedule to another
    100 Club ijnicholas's Avatar
    2005-02
    St Louis, MO and Tirunelveli, India
    130
    Default Copy schedule data from one revit schedule to another
    Here is a script I wrote using Autohotkey to copy data from one revit schedule to another.
    I have attached the executable file, code in txt form and a read me file as zip. I hope this is useful to others. You can keep the exe file anywhere in the system. Before running, make sure you have only two schedule views open in Revit. Please report any bugs. Thanks.
    I have copied and pasted below info from the read me file:
    What the EXE does:
    * The exe checks if a Revit schedule view is open.
    * It shows a help message regarding the prep work.
    * (If you dont want this msg to appear in the future, the
    script saves the setting in your windows registry)
    * Asks for the number of rows and columns that need to be copied.
    * Checks if the numbers entered are in fact 'numbers'
    * Switches to Revit and Window Tiles the views and asks you
    * to close other views.
    * (You can skip this msg too)
    * Asks you to select the cell to start copying from
    * Asks you to select the cell to start pasting to
    * The script starts to copy/paste
    * You can press escape to cancel the script.
    Last edited by ijnicholas; 2009-04-08 at 08:41 PM. Reason: updated the exe to version 1.1
    2005-02
    130
    Default Re: Copy schedule data from one revit schedule to another
    I updated this script. The uploaded file has the new version.
    Now you can select the cell in Revit to copy from and then select the cell to 'paste into'
    100 Club Priit.L's Avatar
    2003-02
    Tallinn,Estonia
    193
    Nice. It really gives more possibilities to interact with Revit. Thinking outside the box now , thanks to you.
    Priit
    Structural Engineer
    Does this work in Revit 2010?
    2010-06
    Quote Originally Posted by ijnicholas View Post
    What the EXE does:
    Does it work in Revit 2010 Italian?
    2005-02
    130
    i have not tested this in 2010 italian. most probabaly it wont work.
    regards
    nicholas.
    2005-02
    130
    Quote Originally Posted by josh.made4worship View Post
    i have not tested it.
  1. 2015: Can't add Data Rows to Schedule
    By vanderloo5 in forum Revit Architecture - General
    Last Post: 2014-11-26, 04:47 PM
  2. 2012: REVIT MEP - Space Schedule and Key schedule
    By jboynton418352 in forum Revit MEP - General
    Last Post: 2011-09-03, 12:38 AM
  3. Setup a Hardware Schedule using a Revit Key Schedule
    By hand471037 in forum Revit - Tutorials
    Last Post: 2010-04-20, 06:53 PM
  4. Schedule data to Database
    By ted.evans in forum ACA Wish List
    Last Post: 2007-02-21, 08:29 PM
  5. Zoning Data schedule
    By Wagurto in forum Revit Architecture - General
    Last Post: 2004-08-23, 03:45 PM
