My kingdom for anyone who can help me to understand how to get things to display properly with this view display range. I have very little hair left to pull out trying to get this all to work. I have spent an incredible amount of time trying to get what should be a normal display of walls, windows and such. If you look at the attached files, you can see the walls as they should be in the level 1 view, but on the roof plan, notice the garage walls that project to the roof are not showing. The front master bath pop out walls, for whatever reason, are not showing. The beams on the back porch are not showing. I've used every concievable combination of numbers in view range and have no understanding whatsoever of how this configuration works.
Thank You
