great prog, very useful.
Can you give more more info on this? I can't get it to do it on my system. Although it does seem to be a bug that you can press "Find" several times without closing the last find. It should de-activate the find button until you exit out of the other find I think...
If you could let me know (either here or on email through the program) what your system is, what exactly you are doing that makes it crash, and anything else you think may be relevant...
Steve
I like this program. Just a couple things, I noticed that if you change the case of the text without changing how the text reads it doesn't update the text file. Also it would be great if you could change the parent of a keynote after it's been created
glad you like it. Regarding the casing, could you give a little more detail? Are you talking about when you are using the edit command and you change the note in the dialog box? I'm not seeing that behavior. Remember that there is an auto-casing function, so if you have that checked it will change the casing automatically, so any purely casing edits you made would be thrown away. If you uncheck that box does that fix it? If so and you do this regularly, you can permanently uncheck it in settings...
In regard to changing the parent after creation, that is a known issue, but not for long...
BTW, I've started a list of people who want to be contacted with updates, if you want to be on it just let me know via email or pm and I'll put you on the list.
Ok, Y'all, New version - 6.0 is posted on our website at www.emc2architects.com\revit_tools.html. The new readme is attached here, look to the bottom for new additions to this release.
Also, as I mentioned, if you want to receive email updates let me know...
Steve
Well the problem with the casing seems to have been resolved in 6.0. The problem was that if you used the right click menu or the drop down menu to change the case it wasn't being updated in the text file. Although like I said it's been resolved in version 6.0
Good, wish granted! . I'm not sure what I changed there, but apparently it was a good change, I like those kind of fixes!
All,
Keynote Manager 6.1 has now been released with a few bug fixes and a few new features. It can be downloaded from our website at www.emc2architects.com/revit_tools.html as usual. I have attached the new readme file for your review.
Enjoy,
Steve
6.2 is available for download. Readme is attached.
Steve
