Hi
I'm drawing a section at 1:50 scale & I'd like to show steels members at their true size so have set the display to Fine Detail. However the X bracing are angles & confuse/obscure.
Is there a way to override the settings?
The only way I can think of, as framing beams are used for bracing, is to create separate families for each of the members I'd use for bracing & set the visibility in them.
Hopefully you know of a better/quicker way?
Thanks in advance
