Thread: Revit Structure Load Bearing hatch/filled region/shade
    2008-12
    Question Revit Structure Load Bearing hatch/filled region/shade
    I am interested in knowing how to show load bearing walls under. My problem is that if i have a Masonry Veneer wall the stud part of the wall is the load bearing and the Masonry is not the load bearing part of the wall. How do I show just the load bearing part to be shaded. Does anyone have any ideas.
    2009-02
    Houston
    686
    Default Re: Revit Structure Load Bearing hatch/filled region/shade
    I would create a new "load bearing stud" material that has a solid fill cut pattern. Then apply that material to the stud layer of your masonry veneer wall. There may be a better way to do it, but this would be my first thought. You could probably achieve the same effect with view templates and/or filters.
    2008-07
    Brisbane (Ex. Swedish)
    349
  1. Hatch load bearing elements under floors/beams
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2012-07-04, 08:30 PM
  2. Align drafting hatch pattern within a filled region
    By mme.peel28292390 in forum Revit Architecture - General
    Last Post: 2012-01-20, 08:29 PM
  3. Filled Region Hatch?
    By Beancud in forum Revit MEP - General
    Last Post: 2008-09-18, 11:06 PM
  4. Filled Region Hatch NOT showing up
    By doug.61606 in forum Revit Architecture - General
    Last Post: 2006-07-18, 04:55 PM
