Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Surveying Bearing/Distance LISP Routine
    2009-01
    20
    Default Surveying Bearing/Distance LISP Routine
    Does anyone know of a LISP Routine that will label a line with the bearing and distance of said line (each entity in single line text)? I had a great LISP Routine that worked in LDD but I can't get it to work in CIVIL3D. Any help would be appreciated.
    Houston
    7,520
    Exclamation Re: Surveying Bearing/Distance LISP Routine
    Here is one (It's not mine, I just found it here on augi)
    Attachment 22623
    2009-01
    20
    Default Re: Surveying Bearing/Distance LISP Routine
    I also found that routine and it is just not user friendly. With the old LISP that I had, all you had to do was type in the routine and select the line in which you were interested in. I have searched for similar routines and have not found any that are as efficient. Thanks for your help though. If anybody knows of anything, please help!!!
    2001-03
    Tallahassee, FL
    1,099
    Line_Label.lsp labels lines, arcs & polyline segments using current text size.
    I have this macro in the CUI:
    ^C^C^P(or C:Label (load "Line_Label.lsp"));Label
    For curves it creates a curve table. Put Line_Label.lsp, Dim_Arc.DWG & Dim_Line.DWG in a folder in your support path. The drawings are inserted as blocks with attributes.
    Tom Beauford P.S.M. - Civil 2013 on Windows 7 Pro
    Design Analysis - Leon County Public Works/Engineering
    Ph# (850)606-1516
    2009-01
    20
    Tom-
    Thanks for the help. I have done everything that you said but I get the following error:
    "Error: no function definition: VLAX-ENAME->VLA-OBJECT". Any ideas?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Quote Originally Posted by jason.bongard View Post
    Tom-
    Run (vl-load-com) before running Tom's attached code. You could also add it to the file at the beginning of the routine. It does not hurt if it is run more than once.
    Houston
    7,520
    Add (vl-load-com) to the top of the file.
    2001-03
    Tallahassee, FL
    1,099
    Thanks R. K!. I always forget not everyone has that in their acad.lsp.
    Ph# (850)606-1516
    2009-01
    20
    Thanks guys. I got the routine to work and it works well. It is a little more advance than what I need. Rather than opening up a separate edit box, does anyone have a LISP routine that will simply label the line with its Bearing & Distance (in single line text format for each entity while matching the size and layer that is current).
    2001-03
    Tallahassee, FL
    1,099
    Quote Originally Posted by BoarsNest01 View Post
    The edit box is mostly so I can clearly see the labeled information.
    You can always remove the two lines that call the attribute editor:
           (command "._DDATTE" (entlast))
    Ph# (850)606-1516
  1. Annotate bearing/distance
    By justinxxvii in forum AutoCAD General
    Last Post: 2009-06-02, 09:35 AM
  2. Northing & Easting Miss Surveying Lisp routine
    By amazingb2003 in forum AutoLISP
    Last Post: 2008-04-23, 06:45 PM
  3. bearing and distance lables
    By eleonard in forum AutoCAD Civil 3D - General
    Last Post: 2007-04-24, 08:41 PM
  4. Annotation - Bearing and Distance - Civil
    By Mlabell in forum Dynamic Blocks - Sharing
    Last Post: 2007-04-05, 11:45 AM
  5. Distance Lisp Routine Help
    By BCrouse in forum AutoLISP
    Last Post: 2006-02-11, 11:41 PM
