Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 60
Thread: Surveying Bearing/Distance LISP Routine
  1. #21
    2005-10
    Default Re: Surveying Bearing/Distance LISP Routine
    You don't need a lisp routine in Civil3D. General/Add labels/ then choose Feature: Line and Curve. Pick the line to label the bearing and distance. Edit the Command Line in Toolspace/Settings/General/Label Style/Line to have the label the way you want it to show.
    Of course, you must have a line first to label. I am using Civil3D 2009.
  2. #22
    2004-08
    Quote Originally Posted by hilln View Post
    What about if I need to label just parts of that line and than again parts of that line. They should left the ability to put labels between two points.
  3. #23
    2012-04
    Angry Re: Surveying Bearing/Distance LISP Routine
    Is there is a lisp function that writes bearing and distance in metric without the foot symbol and and quadrant bearings
  4. #24
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Try this code, not seriously tested though
    ;; local defuns
    ;; draw text
    (defun vk_true_text (txt t0 h ug just / elast)
        (setq elast (entlast))
        (if (= (cdr (assoc 40 (tblsearch "STYLE" (getvar "TEXTSTYLE")))) 0.0)
          (if (/= (strcase just) "L")
            (vl-cmdf "_.TEXT" "_J" just t0 h ug txt)
            (vl-cmdf "_.TEXT" t0 h ug txt)
          ) ;_  if
            (vl-cmdf "_.TEXT" "_J" just t0 ug txt)
            (vl-cmdf "_.TEXT" t0 ug txt)
          ) ;_  if
        ) ;_  if
        (if (/= elast (entlast))
          (entlast)
          nil
        ) ;_  if
    ; Convert value in radians to degrees
    (defun rtd (a)
      (* 180.0 (/ a pi))
    ;;-------------------------------------   main part   ---------------------------------;;
    (defun C:BEAR(/ a ang b curth dist elist en ent gkw mp mp2 osm p1 p2 strang strdist txh)
    (setq osm (getvar "osmode"))
    (setvar "osmode" 0)
    (setq curth (getvar "dimtxt"))
    (initget 6)
    (setq txh (getreal
    	    (strcat "\nEnter the text height <" (rtos curth) ">: ")
    (cond ((not txh) (setq txh curth)))
    (initget 1 "Select Enter")
    (setq gkw (getkword
    	    "\nSelect line or Enter two points (Select/Enter) <S>: "
    (if (eq "Select" gkw)
      (progn
        (setq ent (entsel "\nSelect line: "))
        (setq en (car ent))
        (setq elist (entget en))
        (setq p1	  (cdr (assoc 10 elist))
    	  p2	  (cdr (assoc 11 elist))
    	  mp	  (mapcar '(lambda (a b) (/ (+ a b) 2)) p1 p2)
    	  ang	  (angle p1 p2)
    	  dist	  (distance p1 p2)
    	  strdist (rtos dist 2 3)
    	  strang  (angtos ang 0 2)
        (if	(< (/ pi 2) ang (* pi 1.5))
          (setq ang (+ pi ang))
        (setq mp2 (polar mp (- ang (/ pi 2)) txh)
    	  mp  (polar mp (+ (/ pi 2) ang) (/ txh 2))
        (vk_true_text strdist mp txh (rtd ang) "BC")
        (vk_true_text strang mp2 txh (rtd ang) "TC")
      (progn
        (setq p1 (getpoint "\nSpecify a first point: "))
        (setq p2 (getpoint p1 "\nSpecify a second point: "))
        (setq mp	  (mapcar '(lambda (a b) (/ (+ a b) 2)) p1 p2)
    	  ang	  (angle p1 p2)
     (setvar "osmode" osm)
    (prompt "\nType BEAR to start command")
    (prin1)
    ~'J'~
  5. #25
    2015-08
    59
    Quote Originally Posted by fixo View Post
    ;; local defuns
    ;; draw text
          ) ;_  if
          ) ;_  if
        ) ;_  if
          (entlast)
          nil
        ) ;_  if
    (defun rtd (a)
      (* 180.0 (/ a pi))
    (setvar "osmode" 0)
    (initget 6)
    (setq txh (getreal
    (setq gkw (getkword
      (progn
        (setq en (car ent))
    	  ang	  (angle p1 p2)
      (progn
    	  ang	  (angle p1 p2)
    (prin1)
    ~'J'~
    FIXO; I believe the angle reported by the program is the complement of the angle which needs to be reported. Angle needs to be reported from north or south, not east or west. (angle reported as 16.8 degrees, should be 73.2 degrees)
    Steve
  6. #26
    2005-05
    Pietari, Venäjä
    1,269
    Thank you Steve, but I'm not a math, I'm still waiting for OP response
    Oleg
  7. #27
    2012-07
    56
    Hey, guys
    I need a lisp that label the azimuth & distance by picking a line?
    The azimuth is according to the position of UCS from the AutoCad2012.
    Kind Regards,
  8. #28
    9,805
    Quote Originally Posted by fabricio_camargo84151122 View Post
    Hey, guys
    Take a look at
    http://forums.autodesk.com/t5/Visual...e/td-p/2668454
  9. #29
    2003-11
    450
    See file below.
  10. #30
    2012-07
    56
    modelo.dwg
    Hello guys,
    Thanks for the help but I saw this lisp and didn't work.
    I need lisp that give me azimuth and distance: e.g. 25°26'23" - 15,30m.
    Following attached file as a model.
    Thanks.
  1. Distance Lisp Routine Help
    By BCrouse in forum AutoLISP
    Last Post: 2018-03-21, 02:40 PM
  2. Annotate bearing/distance
    By justinxxvii in forum AutoCAD General
    Last Post: 2009-06-02, 09:35 AM
  3. Northing & Easting Miss Surveying Lisp routine
    By amazingb2003 in forum AutoLISP
    Last Post: 2008-04-23, 06:45 PM
  4. bearing and distance lables
    By eleonard in forum AutoCAD Civil 3D - General
    Last Post: 2007-04-24, 08:41 PM
  5. Annotation - Bearing and Distance - Civil
    By Mlabell in forum Dynamic Blocks - Sharing
    Last Post: 2007-04-05, 11:45 AM
