Thread: Revit Door Fire Rating from Wall Rating
    2008-02
    San Francisco
    85
    Default Revit Door Fire Rating from Wall Rating
    Is there a way to get the door to know what the rating of the wall it is hosted by?
    It seems like the only thing you could do is make a "working" door schedule and make a room parameter that had fire rating and any door that went to or from a room with a rating you would see in the scedule then manually add the rating to the door. Maybe you could do a calculated value but it will still take someone manually entering the fire rating into a room parameter.
    I found this as an old wish list item and I was wondering if anything has been done about it. http://forums.augi.com/showthread.ph...ting+from+wall
    Sean
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,081
    Default Re: Revit Door Fire Rating from Wall Rating
    Still a wish list item.
    ______________________________________________
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    2006-03
    London, UK
    810
    Parameter inheritence in general would be a Nice Thing
  1. Fire Rating Partition Tape using Revit 9.0 Wall Hatching
    By dpollard909366 in forum Revit Architecture - General
    Last Post: 2012-06-07, 03:12 PM
  2. Fire Rating Solution
    By phyllisr in forum Revit Architecture - Tips & Tricks
    Last Post: 2012-03-12, 02:37 PM
  3. Fire rating line for walls
    By Steve_Bennett in forum Style Management
    Last Post: 2007-01-29, 04:15 PM
