Results 1 to 7 of 7
Thread: need lisp routine input a data in CAD
    Member xfirez's Avatar
    2003-10
    Asia
    19
    Exclamation need lisp routine input a data in CAD
    need a routine lisp for export a data from excel to autocad..
    here is the sample from excel files..
    here is the result from excel
    please help me.
    donno how to dis
    but i'll do my best
    2007-07
    Jo'burg SA
    4,344
    Default Re: need lisp routine input a data in CAD
    Check under this link: http://asmitools.com/Files/Programs.html
    The tabcoord.lsp creates a table which you can export to Excel. Or you could modify it to rather save to CSV file. If you want it directly into XLS you'll need to look at Excel's ActiveX interface.
    Edit ... sorry scratch that ... read too fast ... you want it the other way
    Post Re: need lisp routine input a data in CAD
    Oliver,
    This one covers importing and extracting 3D points between Excel and AutoCAD.
    http://autolisp-exchange.com/Forums/.../F3T5P4.htm#31
    Here's the link for the latest version of GetExcel.lsp:
    http://web2.airmail.net/terrycad/LISP/GetExcel.lsp
    2003-10
    Asia
    19
    Quote Originally Posted by Terry Cadd View Post
    Oliver,
    how to apply..?
    donno how to dis
    but i'll do my best
    Oliver,
    Based upon the format of your Excel spread sheet in your first post, the following code will work. Change the Excel filename and path to the filename and path you used. Load GetExcel before you run the example. i.e. (load "GetExcel")
    (defun c:TempPts (/ Row@)
      (GetExcel "C:\\Temp\\TempPts.xls" nil nil);<-- Change Excel filename and path here
      (command "_PLINE")
      (foreach Row@ (cdr *ExcelData@)
        (command (list (atof (cadr Row@)) (atof (caddr Row@))))
      );foreach
      (command "_c")
      (princ)
    );command
    2003-10
    Asia
    19
    Question Re: need lisp routine input a data in CAD
    Oliver,
      (command "_PLINE")
      );foreach
      (command "_c")
      (princ)
    );command
    any other solution?
    donno how to dis
    but i'll do my best
    100 Club hofcad's Avatar
    2005-09
    111
  1. Replies: 16
    Last Post: 2007-05-16, 01:20 AM
  2. LISP Routine to get Object Data
    By gisdude in forum AutoLISP
    Last Post: 2007-05-01, 07:55 PM
  3. Replies: 1
    Last Post: 2007-04-07, 12:39 PM
  4. Replies: 6
    Last Post: 2006-10-16, 05:29 AM
  5. Multiple data input
    By cadconcepts in forum AutoLISP
    Last Post: 2005-10-05, 06:50 PM
