Thread: Material Opacity
    2008-01
    96
    Unhappy Material Opacity
    I have applied a material to an object, which makes the object appear opaque (Glass effect).
    The model appears like glass when viewing using the Realistic visual style, but if I try to view the same material effect using the Conceptual visual style, the model appears solid.
    Can anyone explain why this happens?
    0,0,0 The Origin
    8,570
    Default Re: Material Opacity
    The conceptual visual stype has "material display" set to "off". Creating a new style based on conceptual but with material display set to "materials and textures" might give you the combination you want.
    2008-01
    96
    Thumbs up Re: Material Opacity
    Good Man Jaberwok - Worked Perfectly.
    Thanks.
  1. Solid Hatch Opacity Setting
    Last Post: 2012-09-05, 09:34 PM
  2. opacity texture
    By sam_ctlim in forum NavisWorks - General
    Last Post: 2009-02-23, 07:04 PM
  3. Problem with Opacity File
    By essdubbya in forum Revit - Rendering
    Last Post: 2006-01-19, 07:23 AM
  4. Problem with Opacity File
    By essdubbya in forum Revit Architecture - General
  5. DWF Text Opacity
    By Batman in forum Revit Architecture - General
    Last Post: 2005-07-05, 05:12 AM
