Thread: line heirarchy?
    2003-09
    2
    Default line heirarchy?
    Is there a way to set lines / hatches forward or backward from other entities? Sometimes my plotted 2D drawings have the solid (grey) Bhatch covering the the partition lines . . .
    thanks for your help
    2001-10
    Arizona
    2,337
    Default Re: line heirarchy?
    For pre-2005 versions investigate DRAWORDER
    In 2005 there is a selection when creating Hatches
    as to where to place the boundary object.
    Also check your settings for lines merge/overlap
    as this can impact the plotted output as well.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2003-09
    2
    Thanks Michael . . . draworder was the command I couldn't put my finger on . . .
  1. Projection/Surface Line Color Override negates Line Weight
    By nosten in forum Revit Architecture - General
    Last Post: 2008-09-30, 07:57 PM
  2. Site Property Line - Strange Effect on Model Line Family
    By Batman in forum Revit Architecture - General
    Last Post: 2007-02-08, 03:31 AM
  3. line extends THROUGH line to another line in the drawing
    By mhudson in forum AutoCAD General
    Last Post: 2006-01-20, 08:09 PM
