Thread: Annotative Scaling is BROKE
    Member scott.jeffers's Avatar
    2008-01
    Taxachusetts
    39
    Default Annotative Scaling is BROKE
    Is it just me or is annotative scaling still in it's infancy? I've found nothing but problems with annotative text/hatch/blocks. It seems like 60% of the time I've got to save & reopen a drawing to make annotative objects *work*. Can anybody show me the magic button? Because I'm trying to push an office of stubborn old-timers into the present, but when I demonstrate half of this stuff I wind up looking like an idiot when the blocks/hatch/text don't respond properly. For instance:
    -Insert dynamic annotative callout block. Manipulate dynamic grips. Block disappears, grips remain visible. Hit ESC; block reappears but dynamic geometry has not changed. Fixes itself upon AUDIT or when drawing is restarted.
    -Edit hatch to be annotative. Hatch either disappears completely (yes, anno scale is correct), or hatch origin is lost, annihilating hatch geometry (AR-CONC).
    Any input, or is this on par?
    2003-12
    Pittsburgh, PA
    355
    Default Re: Annotative Scaling is BROKE
    Not magic, but do an audit. You don't need to fix the errors (a bit quicker I think).
    Here's the response from Support when I contacted them about the problem.
    Thank you for contacting Autodesk Support. This issue has been logged with our Development team, in the form of a change request, for further investigation and a resolution. At this time the workaround is to audit the file after a save is performed to restore the editing capability.
    I am linking this case to the known defect. We appreciate your patience as we work on resolution.
    2004-08
    Hartford, Michigan
    3,086
    it was introduced in 08, so depending on what version you are on, yes, it still is in its infancy. annotative hatch is improved somewhat in 09, and I havent been using 10 long enough to know how annotative properties have improved. I'm just happy hatch is easier to grip edit.
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
  1. 2011: Annotative scaling problem
    By petertanderson677259 in forum ACA General
    Last Post: 2011-07-10, 02:41 AM
  2. Annotative Scaling Tips - help.
    By randyspear in forum AutoCAD Annotation
    Last Post: 2009-07-29, 08:02 PM
  3. Transition to Annotative Scaling
    By cj_follmer in forum CAD Management - General
    Last Post: 2008-01-30, 02:59 PM
  4. DBs & Annotative Scaling
    By .chad in forum Dynamic Blocks - Technical
    Last Post: 2007-08-14, 10:06 PM
  5. Concept of Annotative Scaling
    By rmk in forum AutoCAD Annotation
    Last Post: 2007-05-11, 03:08 AM
