(I couldn't remember if I had posted this question in here before, so sorry if it is a repeat)
We use the Project Navigator's (ACA 2009) Project properties, Detailed Information to fill in fields on our sheets. One of these is a Project Progress field that we use to label 50% sets, 90% sets, etc. When we go out to bid, we have to erase this on each sheet as anytime a space is typed in the detailed information, we get the "----" in the field. We don't type in "Bid Set" because the progress sets are generally for in-house and consultants and also where the field is located on the sheet has the revision schedule behind it on a no plot layer. The closest I have come to getting around this is to type in a "."
Also, I have tried the Alt+0160 as seen on the JTB World blog site and have also tried the Ctrl+Alt+Space with no success. The first works in Autocad but not ACA (thanks Autodesk). Any ideas?
