BoKirra
Thanks again.
Another question, what if I want to close one inactive drawing only?
Of course, in this case the code will ask me to input the drawing name.
I'll take more candles before jumping into the dark.
I mean I'll learn it soon.
Let's look at a couple of ways of doing this. First, I would build a subroutine that would close a drawing based on the name of the drawing:
(defun CloseSpecifiedDwg (FileName / docs doc OurDoc)
(vl-load-com)
(setq
FileName (if (wcmatch (strcase FileName) "*.DWG") FileName (strcat FileName ".DWG"))
docs (vla-get-documents (vlax-get-acad-object))
;the collection of all of the currently open drawings
doc (vla-get-activedocument (vlax-get-acad-object)) ;the active drawing
;;Get the document we want to close
;;wrap this in a vl-catch-all-apply
;;in case the drawing isn't open
OurDoc (vl-catch-all-apply
'vla-item
(list docs 1);filename)
(if (vl-catch-all-error-p OurDoc)
;;then the drawing isn't open, notify the operator
(princ (strcat "\nCan't close " FileName " because it isn't open."))
;;else, close it
(vla-close OurDoc :vlax-true)
(vlax-release-object OurDoc)
(vlax-release-object Doc)
(vlax-release-object Docs)
Then we could call it with a this, which will prompt for the drawing name:
(defun c:CloseDwg1 (/ FileName)
(setq FileName (getstring T "\nEnter name of drawing to close: "))
(CloseSpecifiedDwg FileName)
(princ)
This will work, but leaves a lot of room for error - typos, spelling, etc;. With a bit more code we could present the user with a "menu" on the text screen:
(defun c:CloseDwg2 (/)
(vl-load-com)
(setq
indx 1
;;Create a list of the names of all the open drawings
(princ "\n\n Enter the drawing number to close")
(vlax-for dwg docs
(princ (strcat "\n" (itoa indx) ".\t" (vla-get-name dwg)))
(setq indx (1+ indx))
(princ "\n")
(textscr)
(setq OurDwgIndex (getint))
(if (and
(< (1- OurDwgIndex) (vla-get-count docs))
(< 0 OurDwgIndex)
(closeSpecifiedDwg (vla-get-name (vla-item docs (1- OurDwgIndex))))
Which will switch to the text screen and show a menu similar to the following:
1. Drawing1.dwg
2. Drawing4.dwg
3. Drawing5.dwg
4. Drawing6.dwg
5. Drawing7.dwg
6. Drawing8.dwg
I hope this helps show that routines that use vlisp functions don't have to be too complex.
