Results 1 to 1 of 1
Thread: I can't adjust table column width
    2003-11
    427
    Default I can't adjust table column width
    I am trying to create a table that is similar to a block I use for electric panel schedules but I can not adjust column width smaller than 0.24. Is there a minimum column width setting?
    I attached the drawing file, the table is on the bottom.
    **** edit ****
    I had a horizontal margin around my title and header rows, so I change those values to zero and I am now able to make the width 0.12 which works for me.
    Last edited by GreyHippo; 2009-04-01 at 08:57 PM. Reason: I figured out what I was doing wrong
  1. width table column
    By clovis in forum AutoLISP
    Last Post: 2012-01-24, 04:46 PM
  2. Replies: 5
    Last Post: 2009-01-08, 01:35 PM
  3. How do you adjust Title text width on details?
    By jmurray.157028 in forum Revit - Platform
    Last Post: 2008-02-19, 09:15 PM
  4. Column width of open dialog in XP
    By Nic M. in forum Windows XP
    Last Post: 2004-06-07, 04:09 PM
