Results 1 to 6 of 6
Thread: Extremely slow saving
    Member Superdutch's Avatar
    2005-10
    10
    Unhappy Extremely slow saving
    Since we use Revit 2009 together with Windows Server 2003, saving is extremely slow. Three minutes for a 30 MB file is "normal" resulting in severe caffeine intoxication.
    I know saving locally can relieve some pain but this is not really a good option.
    Please help me out?
    Superdutch
    2004-10
    Yorkshire, UK
    398
    Default Re: Extremely slow saving
    Quote Originally Posted by Superdutch View Post
    Please help me out?
    Do you have a gigabit network?
    2005-10
    10
    Quote Originally Posted by Andrew Dobson View Post
    We have a 100 Mb network that worked fine before we moved from Linux Redhead to Windows Server 2003. Regular transfer speed and saving big files in all our other programs (Photoshop, Indesign, etc.) is still fine. We only have problems with saving in Revit.
    Superdutch
    2005-10
    10
    Question Re: Extremely slow saving
    Help, we're running out of coffee!
    Anyone???
    Superdutch
    2004-10
    Yorkshire, UK
    398
    I'm not really sure if all that you changed is the server.
    We have Windows Server and it works fine for us.
    Is Windows server doing DHCP or do you have a router handling it? If there are both running a DHCP server it may create problems.
    You could try static IP addresses on each machine?
    Did you have an IT consultant install Windows Sevrer for you? They should probably be your first port of call, or contact Autodesk support through subscription centre
    2005-10
    10
    Thanks for your suggestions, Andrew!
    I'll do some further investigation.
    Superdutch
  1. 2011: Revit MEP extremely slow
    By Julie.sisk in forum Revit MEP - General
    Last Post: 2012-04-27, 05:55 PM
  2. Extremely Slow Export to DWG
    By michaelf in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-06-05, 07:59 AM
  3. Extremely Slow Export to Autocad
    By michaelf in forum Revit Architecture - General
    Last Post: 2008-05-22, 02:28 PM
  4. Table edit cause PC extremely slow
    By sue.wu in forum AutoCAD LT - General
    Last Post: 2008-03-28, 04:16 PM
  5. extremely slow regen!
    By george11largat in forum AutoCAD General
    Last Post: 2005-06-11, 09:26 PM
