Thread: Mechanical Equipment wont propagate flow (piping) upstream
    100 Club BigBadBIM's Avatar
    2007-07
    Madison, WI
    185
    Default Mechanical Equipment wont propagate flow (piping) upstream
    Mechanical equipment (like a Fan powered box) calculates the flow from "terminal units" and can propagate that to duct upstream.
    Is there a reason that mechanical equipment can't do the same for piping flow?
    I created a "Piping break" family so that I can break DHW and DCW systems into subsystems based on floor or zone (since you can only assign one system to any particulat peice of equipment, like a boiler.) I configured the connectors the same as they are in our Fan Powered Boxes (VSF) and created a PIPING FLOW PARAMETER in the family (similar to the AIR FLOW parameter in our Air Side equipment.) However, the piping flow doesn't behave the same as the air flow.
    Flow (as well as fixture units, which flow is derived from) proagates to the downstream side of the equipment, but stops there.
    Any ideas?
    I also investigated an OOTB water softener (intermediate equipment just like a FPB) and it doesn't seem to propagate that flow either.
    Has anyone else been able to make flow propagate up stream using the piping flow parameter?
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    889
    Default Re: Mechanical Equipment wont propagate flow (piping) upstream
    I have observed the same behavior. Piping is just too screwy right now to get any reasonable calculative benefit it seems.
    2007-07
    Madison, WI
    185
    Quote Originally Posted by mjdanowski View Post
    These inconsistencies make it super hard to get my designers and engineers to WANT to use the product.
  1. Replies: 4
    Last Post: 2012-02-15, 07:54 PM
  2. Replies: 4
    Last Post: 2012-01-31, 07:05 PM
  3. No Piping Flow After Tees
    By dan537c303956 in forum Revit MEP - General
    Last Post: 2011-04-06, 12:38 PM
