Thread: Used rows count
    2009-04
    2
    Default Used rows count
    I am trying to count the number of cells in a sepecific column that contain the letter "x".
    I
    I tried:
    Sub do_count()
    For i = 2 to 5
    MsgBox Sheet(1).Cells(i, 2).UsedRange.Rows.Count
    End Sub
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,776
    Default Re: Used rows count
    Have you tried using the LOOKIUP function?
    C:> ED WORKING....
    Active Member ed.w.cler's Avatar
    2008-02
    Central IL
    53
    I assume you are using MS Excel.
    If you change your syntax a little, this format works for me
    Sub ThisUsedRange()
        Dim Rows As Integer
        Dim Columns As Integer
        Columns = ActiveSheet.UsedRange.Columns.Count
        Rows = ActiveSheet.UsedRange.Rows.Count
        MsgBox "There are " & Columns & " used columns and " & Rows & " used rows."
        Dim xCount As Integer
        Dim Col As Integer  'This is the column in your sheet where you are looking for the "X"
        Col = 2
        For i = 1 To Rows
            If Cells(i, Col) = "x" Then
                xCount = xCount + 1
            End If
        Next
        MsgBox "There were " & xCount & " x's found"
    End Sub
    Let me know if this helps.
    Ed
    Dell Precision T3400 - Q6600 @ 2.4GHz 8GB Ram - Nvidia Quadro FX 3700
    2008-02
    Central IL
    53
    a much easier way to count and sum up data is by using a pivot table. If you are not aware of them, then i think the MS help would be good for you.
    Ed
  1. 2010: Delete or Add Rows
    By eyde in forum AutoCAD Tables
    Last Post: 2012-03-29, 10:04 PM
  2. Can Rows in Sub-Panels pan?
    By Liamnacuac in forum AutoCAD CUI Menus
    Last Post: 2011-10-12, 12:14 PM
  3. DB to create staggered rows
    By nextvkin in forum Dynamic Blocks - Technical
    Last Post: 2009-05-06, 04:23 AM
  4. Numbered rows in schedules
    By radoss in forum ACA Wish List
    Last Post: 2009-02-02, 06:21 AM
  5. Add rows to drawing list
    By mmolina in forum Revit Architecture - General
    Last Post: 2005-11-01, 05:39 PM
