Results 1 to 7 of 7
Thread: Clash Report Formatting?
    2008-10
    Kalamazoo, Michigan
    27
    Default Clash Report Formatting?
    I need to format my clash reports so that they are not "straddled" across the pagebreaks. Basically, the viewpoints/snapshots that reach across multiple pages aren't viewable. Please see attached screenshot (1st image is of the problematic pagebreaks within the PDF and the 2nd image is of the HTML report that I generated the PDF from).
    I like the format that the HTML clash report generates, but when I print a hardcopy to a PDF it doesn't appear to be the same format as the HTML. Do I need to format within NavisWorks or through the PDF writer and how?
    I've also noticed that when I get to about 2,000+ clashes, that I cannot print/convert the HTML clash report. Instead, I get an error and sometimes my computer doesn't even recognize that I sent the print command. Is this normal with such an abundance of clashes or am I missing steps? (Just to clarify, I like to "bind" the HTML and JPG's into one single PDF so that I don't have to transfer all of the necessary JPG's to the project server and that the person on the receiving end can simply print and take with them).
    Is anybody producing clash reports through the HTML option with success? Some of the other NW guru's I've talked to don't even use the XML or HTML reports. Instead they generate their own reports with Excel. I don't want to hop on that Bandwagon until I've exhausted all formatting options with the original report written within NW first.
    BTW, I am using NavisWorks Manage 2009.1
    Thanks!
    100 Club mitch.cornelius's Avatar
    2008-05
    Salt Lake City, UT
    171
    Default Re: Clash Report Formatting?
    I do use HTML and XML. However I hyperlink these to a spreadsheet that shows the clash detection matrices. My final deliverable is a DVD or CD with all reports and the spreadsheet. Instead of opening each HTML file, the excel spreadsheet is opened and hyperlinks open the HTML.
    I can definitely see the benefit of formatting the html file to print on pagebreaks...It might take some more advanced editing of the xml file though. Interesting thoughts....
    2007-06
    Lansing, Michigan
    44
    Quote Originally Posted by mitch.cornelius View Post
    Can you elaborate a bit on how you setup the hyperlink to the excel file?
    2008-05
    Salt Lake City, UT
    171
    I use an export to xml of all the clash tests to populate a sheet within my excel workbook. This sheet is then used to populate my clash detection matrices. I've attached an example of a matrix. Hyperlinks are set up within excel (right click-hyperlink-select file) to point from the cell that represents the number of clashes to the HTML clash report.
    Is that more clear? It's a hard process to explain.
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    You can get it to print better by going to page setup in internet explorer and setting margins as small as they'll go and get rid of the header/footer. To get page breaks you would have to manually insert code into the html
    Place the following code in the HEAD of the html:
    <STYLE TYPE='text/css'>
    P.pagebreakhere {page-break-before: always}
    </STYLE>
    Then place the following code in the BODY of the html where you want the pagebreak:
    <P CLASS="pagebreakhere">
    I just send the html with the jpgs, but our projects are fairly small in comparison. As for printing that large of a file you may be running out of ram or it may be the pdf writer crashing
    2015-12
    2,062
    Thanks for the reminder of the XML output. Given my latest binging on XSD Schema and XSLT Transform information, I might be able to leverage that for additional reporting.
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    100 Club cdsuggs's Avatar
    2008-04
    LA area
    146
    You have a link within excel that reads the XML data and generates the matrix? Would love some insight if it do ya.
    _________
    suggs
  1. 2013 Formatting Excel Panel BOM Report
    By kstlaurent684682 in forum AutoCAD Electrical - General
    Last Post: 2014-12-05, 09:52 PM
  2. Clash Report Summary Plan View
    By Wish List System in forum NavisWorks - Wish List
    Last Post: 2013-09-22, 12:44 PM
  3. More Clash report Customization
    Last Post: 2013-02-11, 08:03 PM
  4. Clash Report
    By tonyisenhoff in forum NavisWorks - General
    Last Post: 2011-12-06, 03:15 PM
  5. Automate Clash Report Generation
    By potapczuk542577 in forum NavisWorks - General
    Last Post: 2011-06-09, 06:38 PM
