Thread: Sheet Set Numbering
    100 Club red2002yzfr1's Avatar
    2002-04
    Allentown PA
    141
    Default Sheet Set Numbering
    I am giving the sheet set a try and the one problem that I am having is that we number our "layouts" in the following mater, 01.01, 01.02, 01.03, 02.01, 03.05, etc. Now when I create a new sheet set from our master title block, these numbers come in as the sheet description, not the sheet number. Now if I name the "layout tab" the description of the sheet, the sheet description will come in correctly, but in alphabetical order. Therefore I have to re-order them and put in the drawing number. Is there a way to have this information come in with the sheet numbers being sheet numbers and sheet descriptions being descriptions with out all the manual input?
    I could stop if I wanted to acad's Avatar
    Roanoke, VA
    355
    Default Re: Sheet Set Numbering
    Try using Project Navigator instead of layout tabs.
  1. Sheet Numbering without the A prefix
    By nextvkin in forum Revit Architecture - General
    Last Post: 2011-03-23, 02:28 AM
  2. Automatically update sheet set numbering
    By jamie.casile in forum AutoCAD Sheet Set Manager
    Last Post: 2005-12-26, 05:26 PM
  3. Sheet Numbering
    By Cathy Hadley in forum Revit Architecture - General
    Last Post: 2004-09-13, 10:52 AM
  4. Drawing Numbering on the sheet
    By rlwade.68242 in forum Revit Architecture - General
    Last Post: 2004-08-20, 04:04 PM
