Thread: how to dimension arc lengths?
    2004-12
    126
    Default how to dimension arc lengths?
    how to dimension arc lengths in sketches, or at least find out how long an arc is? I know you can do an arc length dim in idw, but what if arc length is important to me as part of my sketch construction?
    Mike
    Williamsport, PA
    641
    Default Re: how to dimension arc lengths?
    Quote Originally Posted by Mike Y View Post
    .... but what if arc length is important to me as part of my sketch construction?
    Simply set the length up as a parameter given that circumference = pi2r(360/360)
    If you can't figure it out I'll post an example tomorrow when I get back to work.
    This question has been covered many times over here http://discussion.autodesk.com/forum.jspa?forumID=78
    a search might turn up the example.
  1. Add up line lengths
    By bmckenzie in forum AutoLISP
    Last Post: 2014-01-03, 06:32 PM
  2. Duct Lengths and Flanges
    By Mikeyspeed in forum Revit MEP - Families
    Last Post: 2010-03-02, 02:23 PM
  3. polyline lengths
    By eebryant in forum AutoCAD Map 3D - General
    Last Post: 2006-11-04, 01:18 PM
  4. tangents and lengths
    By Richard McDonald in forum AutoCAD General
    Last Post: 2006-10-30, 11:03 AM
  5. Arc Lengths
    By justin.hosler in forum Revit Architecture - General
    Last Post: 2004-12-10, 04:59 PM
