I posted the questions below in the Autodesk discussion groups yesterday, but so far have not received a reply, so when I saw this thread, I thought I might ask here as well.
If our office upgrades to Revit Structure 2010 from RS2009, will we now be able to 'downversion' our model files (or newly created custom content in 2010) so as to be used in RS2009, if needed? (I understand this has been an issue in previous releases(?), correct me if I'm wrong.)
Now - if we happen to be working with an Architectural client who is still using RA2009, will we be able to provide model files for them to be able to use for coordination?
I'm hoping at this point that the answer is 'yes' to both questions. Does anyone know for certain? (I understand that any newer 2010 'enhancementes' over 2009 would not be available to use in older versions, but what about items that haven't really changed from older versions?)
If the answer is 'no' to either question, then what is the solution, given that we cannot force our clients to upgrade? - Or are these questions simply considered to be non-issues and therefore not a problem?
Sincerely,
David Kozina
