Hi All,
I am working on construction documents and for some reason when I create a detail callout on a wall section it also shows up in the 1/4" building section. Is there a way of controling this without the hide in view option.
Dan
Hi All,
Dan
From the callout view properties you can set it to hide as scales coarser than "x" Set that to whatever size you want.
Scott D. Brown, AIA
BECK
For some reason that option is showing up as non-editable. Any thoughts?
In the Show In option I had to select Intersecting Views, then the Hide at Scales Coarser Than lit up.
Thanks!
