Results 1 to 8 of 8
Thread: viewport ontop of viewport!
    2009-03
    5
    Cool viewport ontop of viewport!
    I have a drawing with a viewport of a floorplan. I would like to have a smaller viewport ONTOP of the overall plan showing a magnified view of the area. I want the smaller viewport to hide what's behind it on the overall. This is something I haven't come across because you wouldn't do this for design, but it's for presentation purposes.
    Does anyone know how to do this? I can only compare it to images which are set not to transparent. I feel like there must be some way to do this.
    HELP!
    Cairo - no, not Illinois
    2,715
    Default Re: viewport ontop of viewport!
    nope
    what you can do is clip your underlying viewport around the inset viewport.
    Officially Awesome
    0,0,0 The Origin
    8,026
    Make two rectangles, convert them to regions, subtract one from the other, make a viewport from the region (MV/ Object).
    Place a simple viewport in the space.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    All AUGI, all the time TerribleTim's Avatar
    2006-03
    Tacoma, Wa
    627
    Jennifer, I get what you are trying to do and I want to see if I can help. We've done some funky stuff like that in the past here.
    So, the secret is this -
    Draw the boundary of the first viewport (the big one of the whole plan) as a polyline and be sure it is shaped the way you want it with the hole in the middle of it for the second viewport. The key is to remember that polylines can always overlap other parts of their self. Then, when you type in "mview" to create a viewport, use the "select object" option to select your polyline with the hole in the middle of it.
    Once you have that viewport the way you want it, make another viewport in the hole. Remember, you can get it close and then use the stretch tool to get it just right later.
    Play around with that theory and see how you do. Hope that helps you out.
    Tim McDougald
    CAD/BIM Manager / Assistant P.M.
    KMB Design Groups, Inc. P.S.
    828 7th Avenue SE - Olympia, Washington 98501
    HayWire Racing
    1101 124th Street South, Suite B - Tacoma, Washington 98444
    2007-07
    Jo'burg SA
    4,344
    Here's a solution which may work:
    1. In Model Space (tab, i.e. TILEMODE=1), create a layer which will only be displayed in the smaller VP. Call it something like VP-Background. Make this layer current.
    2. Draw a WIPEOUT on this layer over the area which you're going to show in the small VP.
    3. Select the WIPEOUT, right-click Draw order --> Send to back.
    4. Got to the Paper Space layout tab, enter the large VP (double click inside it) & VPFreeze the layer you created. Type PS to return to normal Paper Space.
    5. Select the small VP, right-click Draw order --> Bring to Front.
    The Paper space display doesn't show properly, but check what happens in a plot preview
    2006-10
    50
    Quote Originally Posted by TeriblTim View Post
    yeah but you have to make the first viewport with the hole into a region, as Jaberwok says.
    oh no, you mean use one single polyline to shape round the hole as well ? hmmm .. I suppose thats one way to do it *blink*
    0,0,0 The Origin
    8,026
    Quote Originally Posted by tracy.findlater View Post
    Tim's quite correct (though ambiguous) but the Region method is quicker.
    John B
    I could stop if I wanted to nextvkin's Avatar
    2007-07
    315
    Came across this today - had to do a similar thing - found Tim's solution very useful as it allows the 'hole' to be moved, stretched, almost whatever. Thanks for that!
  1. Replies: 13
    Last Post: 2011-09-10, 11:16 PM
  2. Viewport Title Location In reference to viewport
    By BSaunders in forum Revit Architecture - General
    Last Post: 2010-10-27, 03:54 PM
  3. Replies: 2
    Last Post: 2006-06-16, 07:06 AM
  4. Smaller Viewport to hide / mask part of a larger Viewport
    By thomas.stright in forum AutoCAD General
    Last Post: 2006-04-05, 11:03 PM
  5. Replies: 4
    Last Post: 2005-10-06, 01:00 PM
