Results 1 to 7 of 7
Thread: if filter text equals "*" insert block "*"
    2007-05
    Brookfield WI
    331
    Default if filter text equals "*" insert block "*"
    Trying to use a filter to search titleblock for specific state(s), if state A insert block for state A and so on
    not sure if this helps but wildcard equals city.
    example filter:
    (setq ssvi (ssget "x" '((0 . "TEXT") (1 . "*, VIRGINIA"))))
    (setq sswi (ssget "x" '((0 . "TEXT") (1 . "*, WISCONSIN"))))
    how do I get it to insert block after filter finds text?
    I could stop if I wanted to msretenovic's Avatar
    2002-02
    Galloway, Oh
    305
    Smile Re: if filter text equals "*" insert block "*"
    Quote Originally Posted by d_m_hopper View Post
    example filter:
    You can check to see if you have anything in your selection set. If you do, then you can do an insert. Something like:
    (if ssvi
      (progn
        ;;insert block
    );;end if ssvi (Virginia)
    (if sswi
      (progn
        ;;insert block
    );;end if sswi (Wisconsin)
    These are simply testing if a selection set was made. If there are no text objects that match your criteria, then the selection set will be nil.
    However, alternate code (depending on your needs) could be written as this:
    (cond
      (ssvi
        ;;insert block
      );;end ssvi (Virginia)
      (sswi
        ;;insert block
      );;end sswi (Wisconsin)
    The difference is this code will stop and execute the first match while the other method using IF for each would execute for each match. I assume you would only need it to execute once (for the first match) as you state you are retrieving the information from your titleblock; of which I assume you only have one project per file. If this is the case, the second method shown (with the COND) would be a better choice.
    On another note, you may want to add an asterisk (*) to the end of the text to be searched as well. This would ensure that if the name of the state was located in the middle of the text, it will still be found. Currently, it will only match those that have the name of the state at the end. So, even something such as "RICHMOND, VIRGINIA " would match if your search was "*, VIRGINIA*" (notice the extra spaces). With your original ("*, VIRGINIA"), it would be missed. Just want to make sure you are aware of this
    2007-05
    Brookfield WI
    331
    Default Re: if filter text equals "*" insert block "*"
    Thanks, one for the "*" tip at the end of the text I am filtering for, that will help when filtering for words in foreign countries where the text string ends in the country name. Example we use Toronto, Ontario, Canada
    Secondly a selection set was created, I tested for that, what I was doing was saying if VIRGINIA insert block, not if ssvi insert block.
    2002-02
    Galloway, Oh
    305
    No problem on the "*" tip, I've had tests fail for the same reason and just wanted to pass it on
    2004-08
    Iron Station, NC
    3,198
    example filter:
    your current search will put all text in the selection set with the *. If you want to search for the City, Virginia, you may have to put a ` before the comma, so it is read literally as a comma, not as a divide between two text filters. If you could post more of your code, it would be a little easier to tell you how to insert the block. I would assume that you would want to use a condition
    (cond
    (setq ssvi (ssget "x" '((0 . "TEXT") (1 . "*`, VIRGINIA"))))
    (command "insert" "whatever the rest of the prompts are")
    2015-11
    Jo'burg SA
    4,512
    Yep, that's just it, the comma is used to separate different filter criteria. For example "*test1,*test2" will filter everything ending in either test1 or test2. The way of getting round this is (as ccowgill states) prefixing any control character with a reverse qoute (`). From the developer's help these are the control codes used in wcmatch (which are the same as that used in ssget:
    Wild-card characters
    Character           Definition
    #(pound)            Matches any single numeric digit.
    @(at)               Matches any single alphabetic character.
    .(period)           Matches any single nonalphanumeric character.
    *(asterisk)         Matches any character sequence, including an empty one, and it can be used anywhere in the search pattern: at the beginning, middle, or end.
    ?(question mark)    Matches any single character.
    ~(tilde)            If it is the first character in the pattern, it matches anything except the pattern.
    [...]               Matches any one of the characters enclosed.
    [~...]              Matches any single character not enclosed.
    -(hyphen)           Used inside brackets to specify a range for a single character.
    ,(comma)            Separates two patterns.
    `(reverse quote)    Escapes special characters (reads next character literally).
    2007-05
    Brookfield WI
    331
    Quote Originally Posted by ccowgill View Post
    (cond
    what have assumed is correct and thanks for help. originally I was just going to put the notes on a palette, but decided to attempt to put this on the end of our titleblock routine, for accuracy sake.
    Quote Originally Posted by irneb View Post
    thanks for the above information, my favorite wildcard is "*", I had a drafter use it to change all the 1's to *, but she did not select the text, she just hit find then replace all, never caught it and saved the drawing, oh what fun she had undo-ing that.
    thanks to both of you for the help
  1. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  2. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-01, 04:21 AM
  3. How to show "last printed" or "path" text in layout
    By cstone in forum AutoCAD General
    Last Post: 2008-11-29, 12:05 AM
  4. HOW switch COMMAND "BLOCK" THE "Scale Uniformly"
    By viz_ken1030 in forum AutoLISP
    Last Post: 2006-11-17, 12:41 PM
  5. System variariable for "invert filter" and "apply to layers toolbar" checkboxes
    Last Post: 2005-11-23, 05:58 PM
