Thread: Daylight Lines
    2008-10
    14
    Default Daylight Lines
    Ok I am using Civil 3D 2009. I am creating Flat Pads that are approx. 200 x 400. My Finish Grade surface is sloping to the Existing surface. So where the surface's meet they show the daylight line. But what I need to do is instead on tracing the outline is their a way the make a 3dpolyline from that. I need this because I need to trim a few sections and sense it is part of the surface you can't trim it? Does anyone have any ideas or do you need more information ? and what info?
    2001-05
    Austin, TX USA
    2,201
    Default Re: Daylight Lines
    You can explode the grading object. The daylight line will be left behind. Then you can convert it into a feature line then add it to the surface. While you make your changes it will update the surface.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
  1. Daylight autonomie
    By Eduard in forum Ecotect Analysis
    Last Post: 2011-06-19, 08:42 PM
  2. help me about daylight
    By diyarymin in forum AutoCAD Civil 3D - Corridors
    Last Post: 2011-03-05, 01:51 PM
  3. Daylight Portals
    By Jmickledesign in forum Revit Architecture - General
    Last Post: 2008-05-09, 07:51 PM
  4. animating daylight
    By nullah79 in forum 3ds Max - General
    Last Post: 2007-11-15, 02:34 PM
