Thread: Underline Text in an Attribute
    26
    Default Underline Text in an Attribute
    I want to define an Attribute with text that is underlined.
    In this case a simple Subtitle attribute.
    But the problem is that as its single line text "%%u" has to be used to define the text to underlined. When doing this however it as well as underlining the text, also extends a little past the begining of the text. Refer attachment.
    Now when you use MTEXT and underline the text this problem is not apparent, there is no extension outside of the selected word underlining. But that is no use to me since MTEXT can't be defined in an attribute. Or can it is there an AutoLISP routine that allows this? I not my problem still stands.
    Any Ideas???
    13,624
    Default Re: Underline Text in an Attribute
    Hi
    Have a browse through the following threads -
    MText with Attribute
    Fields in Blocks
    Attributes
    Wrapping text in attributes
    Have a good one, Mike
    0,0,0 The Origin
    8,569
    It appears to be because the font definition includes a leading gap for each character - I suppose that's why text characters don't all run into each other.
    Anyway, I just tried a few fonts including the Solid Edge ISO font and that was close to "the ideal".
    John B
  1. Changing Text that is underline
    By adeuley in forum Revit - API
    Last Post: 2012-05-30, 08:47 PM
  2. select all underline text/ lowercase text
    By avatar in forum AutoCAD General
    Last Post: 2009-07-31, 11:52 AM
  3. Underline Attribute
    By viswaprakash in forum AutoCAD General
    Last Post: 2008-09-22, 05:05 PM
  4. underline text
    By ron.fisch in forum AutoCAD General
    Last Post: 2005-04-21, 11:20 PM
