Thread: Opening Multiple Drawings on Autocad Land Desktop 2009
    2008-11
    8
    Smile Opening Multiple Drawings on Autocad Land Desktop 2009
    Guys!!!
    Does anyone of you there knows how to open multiple drawing files with only one program of Autocad Land Desktop 2009?
    Can i open one existing drawing with a project and the others are not in a project?
    Thank
    2006-10
    7
    Smile Re: Opening Multiple Drawings on Autocad Land Desktop 2009
    Hi,
    I have 2008 LDD on my PC (so i will assume that they are sort of the same).
    Althought you can open multiple drawing in LDD this was some what pointless as it locked the terrain model when you have more than one drawing open, & you really couldnt use LDD as 3D, but more as 2D AutoCAD..
    The solution i use is Map, which came on the 2008 LDD CD.. I run the 2 programs at the same time, & TAB across from the LDD (3D) to the MAP (2D)..
    Hope that helped...
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    Default Re: Opening Multiple Drawings on Autocad Land Desktop 2009
    Besides the fact that LDT commands stop working, as stated above, there is a chance that you can corrupt databases when you have more than one drawing open in LDT. Our company policy is one LDT, one drawing. If we need more than one drawing open we use Map or C3D.
    Jeff Paulsen
    100 Club jmeyer.186809's Avatar
    2008-06
    The Yay! (Bay Area, CA)
    131
    i've been running multiple drawings in window mode and at the sametime running multiple lddt sessions at once for years and have never had a problem.
    Quote Originally Posted by jpaulsen View Post
    Active Member nelson's Avatar
    2001-10
    Portland, MI
    72
    I agree with jmeyer to a point. I have had two or more sites open each with their own session of LDD. I have also had multiple LDD sessions open with the seperate drawings accessing the same project files, but I found that I can't access the point database. So doing a rebuild on the surface can't be done, but I can sample the surface, and I have had no problems with aligments and profiles.
    But I would suggest that you use Land enabled Map for all your multi-drawing needs. I do all the design work in one session of LDD, and open all the sheets for printing and such in Land enabled Map. I found that if you try to work LDD with SDI mode off, or switch back and forth, you run into problems with the session of LDD. Either the session profile screws up or you have stablility issues.
    "If it can be done, it will be done, it shall be done... Tomorrow"
    --My Wife (3 years before we got married)
    And I hold her to it!
    2009-06
    Hi,
    Can someone tells if is possible after import the HEC-RAS file into AutoCAD with the HEC-RAS import/export extension, see the bounds/polygon of the results of Water surface?
    In my case, only appears the river/alignment and the water surface extents but without the values of elevation, it´s normal?
    There is another way to can see the polygon with the water attributes?
    thanks
    Nanda
  1. Opening multiple drawings from outside AutoCAD
    By Coffee Coffee in forum AutoCAD General
    Last Post: 2010-06-28, 02:51 PM
  2. Images within AutoCad Land Desktop C 2009
    By jsraider in forum AutoCAD Civil 3D - General
    Last Post: 2008-07-12, 12:00 PM
  3. AutoCAD LT 2006 - Opening multiple drawings within same session
    By lazer2go in forum AutoCAD LT - General
    Last Post: 2006-11-30, 09:00 PM
  4. Replies: 6
    Last Post: 2006-11-13, 07:08 PM
  5. opening drawings in land desktop
    By 348PATTERSON in forum AutoCAD Land Desktop - Wish List (Closed)
    Last Post: 2005-09-22, 11:11 PM
