I've received a Revit project file from architects. When I opened it I got a message (see attached file). And file can not be opened. What does it mean and what to do to overcome this problem?
Welcome with any suggestions.
How about trying Marx instead?![]()
But seriously, folks....
If this is 8.1, did you try unchecking the "Detach from Central" checkbox?
Yes, and "Audit" too - without the result.Originally Posted by DaveP
Help. This happened to me too. The file I was working on the other day will not open. What do I do?
We just ran into the same issue today. We are using Revit Architecture 2008 build #20070324_1700. The files were worked on just last week and everything was running smoothly.
I filed a support request but was wondering if anyone has had any resolution regarding this issue.
Answer for us was found!!!!!!!
Refer to my next post in this thread.
We are using Revit 2008 SP1
It seems like you are trying to open the file from a networked drive or a memory stick. Why don't try opening the file on your hard drive.
C:\Documents and Settings\(your user name)\Local Settings\Temp
Sort By Date Modified,
I found a file named something like this with no file extension:
revittemp_2LEE7JNFGV9F280L59U1Q5D4VH5
I changed the name and added the .rvt and it was the file I was looking for and it worked.
