Results 1 to 10 of 11
Thread: What's the difference between (getenv) and GetSystemVariable?
    Turlock, CA
    6,526
    Default What's the difference between (getenv) and GetSystemVariable?
    I'm working on a function to integrate with the MOVEBAK command. This command creates a sysvar called ACETMOVEBAK and its value can be returned with the lisp (getenv) function. VBA and .NET api funcions do not access this variable. What's the difference and is there a way to access it with .NET?
    C:> ED WORKING....
    LinkedIn
    2005-08
    1,043
    Default Re: What's the difference between (getenv) and GetSystemVariable?
    As far as I know, ' getenv ' stands for get environment variable, where the other is just a system variable. Environment variables are stored within the registry, and are case sensitive. One example is
    (getenv "acad") = nil
    (getenv "ACAD") = string of the search paths, separated by by semicolons.
    I could be totally wrong, but that is my understanding of them.
    2006-08
    Brisbane : GMT+10
    87
    This may give you some ideas
    [oldurl]http://www.theswamp.org/index.php?topic=20237.msg246496#msg246496[/oldurl]
    http://www.theswamp.org/index.php?to...2446#msg362446
    Turlock, CA
    6,526
    Quote Originally Posted by T.Willey View Post
    I understand that Tim, Sorry its been while since I've dealt with this area of the api. I used the wrong term. What I need is an equivalent to (setenv "AcetMovebak").
    C:> ED WORKING....
    LinkedIn
    Turlock, CA
    6,526
    In the registry, its under Fixed Profile>General.
    C:> ED WORKING....
    LinkedIn
    2006-08
    Brisbane : GMT+10
    87
    P/Envoking the acedGetEnv and acedSetEnv seem to address the registry location Fixed Profile->General.
    I've updated the code at the link posted previously.
    a tip for viewing code at theSwamp. In your profile, Look and Layout .. Change The Current Theme to Mercury which uses a full width and height code pane .. saves the horrible wrapping of code lines and vertical scrolling we see sometimes
    Regards
    Kerry
    2006-08
    Brisbane : GMT+10
    87
    yes, of course !
    Thanks Tony.
    Regards
    Quote Originally Posted by tony.tanzillo View Post
    Quote Originally Posted by Kerry Brown View Post
    http://www.theswamp.org/index.php?to...446[/quote]
    Except you don't need StringBuilder in acedSetEnv(), just a String will do.
    Turlock, CA
    6,526
    Regards
    Kerry
    Thanks alot for both tips.
    C:> ED WORKING....
    LinkedIn
    2006-08
    Brisbane : GMT+10
    87
    2
    you're welcome.
    How many questions do I need to answer to become a shining star ??
    2005-08
    1,043
    you're welcome.
    You're answers have to effect enough people so that they want to add to you're reputation. The little scale thingy under your name.
  1. What's the difference
    By Tharwat in forum AutoLISP
    Last Post: 2010-09-09, 08:48 AM
  2. ??? $(if, $(=, $(getenv, r4n), pr), " ", FIX IT)
    By piper in forum AutoCAD Fields
    Last Post: 2007-11-13, 03:45 PM
  3. What's the difference between Max & Viz.
    By Paul P. in forum DV - The 3rd Dimension
    Last Post: 2007-05-16, 07:01 PM
  4. Replies: 1
    Last Post: 2007-01-25, 02:52 AM
  5. Hidden Candy (getenv "xx" )
    By kennet.sjoberg in forum AutoLISP
    Last Post: 2005-10-26, 12:32 PM
