Results 1 to 6 of 6
Thread: Dynamic Intelligent Leader !
    2005-09
    Canada
    214
    Default Dynamic Intelligent Leader !
    Hi all..
    I need beta-tester for my new routine..
    DILEADER v.1.2
    (Dynamic Intelligent Leader)
    Allow user to quickly put/tag some object.
    Easy to use...you can put any DIL you want on a simple object.
    You can edit the Text leader, Move , stretch...
    The Leader is intelligent and know what Object is tagged.
    so if it was moved, stretched,rotated etc...DIL will know and will readjust the leader on it.
    Need comments on the idea and concept.
    thanks.
    There is Some animation...
    2007-04
    25
    Default Re: Dynamic Intelligent Leader !
    hi
    good lisp sir very usefull
    2009-03
    London, England
    304
    Smile Re: Dynamic Intelligent Leader !
    I wondered when I'd be seeing this on here :P
    Very nice Andrea.
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Great! 2 Queries:
    • Would it be possible to create MLeaders instead?
    • What about adding an object reactor. If the source object is moved, the leader could update automatically (no need for DILEDIT after a move).
    2009-01
    47
    Good idea,
    Same happens when you drag the text you've written. The "leader" doesn't follow.
    I think that it should be a leader which asks you for a text placement which afterwards can be dragged.
    With MLEADER you can stretch the little line in front of the text but I guess it should be easier from the start to ask for text placement so users can decide how "stretched" that line should be.
    2005-09
    Canada
    214
    thanks guys...
    I think all it's possible..
    This release is the first step and allow user to quickly make some modification..
    I've only put reactor on grips fuction so you can move, stretch, rotate as you wish.
    the think is that did not use regular command to allow more flexibility. But feel free to add-it at the reactor section if you need.
    I will working shorlty to add :
    - block recongnition
    - annotative scale.
    - quick Arrow switcher by pressing tab or something like that.
    If you have some more idea to improve it....don't be shy to share !
  1. Convert Intelligent Navis works models to Intelligent AutoCAD MEP Models.
    By Wish List System in forum NavisWorks - Wish List
    Last Post: 2015-04-23, 03:22 PM
  2. Intelligent interaction between leader/mleaders and entities
    Last Post: 2014-10-21, 02:33 PM
  3. dynamic leader?
    By thecadalyst.252480 in forum AutoLISP
    Last Post: 2012-02-28, 04:45 PM
  4. DiLeader - Dynamic Intelligent Leader
    By andrea.andreetti in forum AutoLISP
    Last Post: 2009-09-04, 11:51 AM
  5. Follow the Leader (an intelligent Block)
    By sun.dance in forum AutoCAD Customization
    Last Post: 2007-06-29, 04:49 AM
