Thread: Changing title block families
    2004-06
    Memphis TN area
    7,048
    Default Changing title block families
    I'm trying to figure out a faster way to change title block families in sheet views, either by selecting multiple views and changing it through the sheet's view properties, or through a schedule. To do so would require (I think) some sort of shared instance parameter that makes the title block family used in a sheet view appear in that sheet view's instance parameters.
    Would it be possible to do something like this? As it is now, I have to manually open each and every view if I need to change the title block. Of course this usually only happens because I need to switch from a preliminary title block to one with a scanned image of a signed stamp. And since I can't set visibility parameters for scanned images, I have to do it as separate families.
    *edit* being able to have the "Appears in Drawing List" sheet view parameter appear in a schedule would really be helpful, also.
    2003-04
    Chino, CA
    4,756
    Default Re: Changing title block families
    Right click on one titleblock in project, pick select all instances, then select new titleblock from the type selector pull-down. All titleblocks of that type change at one.
    2004-06
    Memphis TN area
    7,048
    DOH!!! duhh I use select all instances all the time for other things. Don't know why I didn't think of that for title blocks.
    2005-11
    60
    You can put a visibility parameter on a scanned image if you first put it in its own family, make that family shared, and load it into your title block. You can put the visibility parameter on the seal family.
  1. 2015: Changing the View Title
    By kcover in forum Revit Structure - General
    Last Post: 2014-10-10, 06:44 PM
  2. Changing View Title
    By Carlos GT in forum Revit Architecture - General
    Last Post: 2008-12-20, 06:27 PM
  3. Title Block Families....
    By mickaeL_renauD in forum Revit Architecture - General
    Last Post: 2008-10-16, 04:16 PM
  4. View Title Changing
    By michaelf in forum Revit Architecture - General
    Last Post: 2007-08-17, 03:46 PM
  5. Convert MDT Title Block to Inventor 10 Title Block
    By julesgordon in forum Inventor - General
    Last Post: 2005-07-18, 08:34 PM
