IN one of my drawing there is 2 mtexts are there one is copy of other. When I am Printing one is showing in Bold & One is showing regular. All Properties of the Sentence is same. Is any one can help me to sortout this issue
thanks
Suresh
thanks
Suresh
G'day sura69
Please note I have *moved* this thread from the Local Chapters forum to this one, as I believe it will be better served here.
Cheers Bill
Local Chapters Forum Moderator
I noticed that the elevation of one of them was just barely above zero, change units to show as many decimal places as possible. The defined height was really large on one also, not text height. After I changed all that to zero, I move everything to 0,0,0 grabbing the insertion point of the mtext and the two then looked the same.
Normally just getting them at the same elevation will correct the problem.
Dear Friends,
I sorted out this issue.it is very simple
Step1- Select all Mtext in this drawing.
Step2- go to Change Properties. In the Change properties Geometry menu Change "Z "value "0". ( if it showing even "0.00000" just simply type "0" the problem will be get solved)
thanks
Suresh
