Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: How do people load their LISP routines?
    AUGI Addict Mr Cory's Avatar
    2007-01
    Under a Rock over there
    1,006
    Smile How do people load their LISP routines?
    Hay everyone,
    I was just after everyones opinion on whether its best to add all ones customs lisps to the acad.lsp or keep them seperate and just add the line (load "blah blah.lsp" " ") to acad.lsp?
    Earth
    9,832
    Lightbulb Re: How do people load their LISP routines?
    Quote Originally Posted by Mr Cory
    Hay everyone,
    First off, it doesn't do any good to use "acad.lsp", because this file is only load once per session*. Lisp files must be loaded for each drawing that is loaded. "acaddoc.lsp" loads once per drawing, you should use this instead.
    I would suggest using the externally defined (autoload) function to load your lisp files in "acaddoc.lsp". This way the file doesn't actually load until it's needed. For more information, look up "autoload" in the Help file (acad_dev.chm).
    If you are not going to do that, then it doesn't really matter which method you choose. For the record, almost all our lisp functions are stored in separate files, with the exception of "universal" small routines like DTR, RTD, which are defined in "acaddoc.lsp".
    * unless ACADLSPASDOC is set to 1, which it shouldn't be
    R.K. McSwain | CAD Panacea |
    2007-01
    1,006
    Default Re: How do people load their LISP routines?
    O right, well beasically at the moment i have all my lisps either in acad.lsp of loaded from it. I have "load acad.lsp with every drawing" so you think i need to change how things are set up?
    2004-08
    Iron Station, NC
    3,198
    I dont use acad.lsp, I just load everything through acaddoc.lsp using a combination of load and autoload.
    Earth
    9,832
    AutoCAD is designed so that acad.lsp is used to load items that need to be loaded "once per session", and acaddoc.lsp is used to load items that need to be loaded "once per drawing"
    You are using "acad.lsp" like it was back in R14 and earlier, before AutoCAD introduced MDI.
    More Info: http://rkmcswain.blogspot.com/2006/0...setup-and.html
    2004-07
    Detroit Michigan
    2,508
    I have all of my lisp routines loaded in the startup suite.
    That may be why CAD loads somewhat slow.
    Judging by the comments, I am guessing it is not the best way
    to load routines.
    But hey, it works!
    Earth
    9,832
    Talking Re: How do people load their LISP routines?
    Quote Originally Posted by Robert.Hall
    I don't know about slow, but the Startup Suite has had problems since it was introduced. For some it fails to load some items, for others it loads items twice. It's not as easy to migrate that list at upgrade time either, not to mention difficulties in a multiple user environment.
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by rkmcswain
    All very good points. I find that some routines have not loaded. Does not bother me too much because I rarely lose a routine that I use often.
    In addition to your cons, startup suite limits the number of lisp files you can load on the "add a file" screen. The user cannot surf to a directory, select all, and then add the entire folder. The lisp files would need to be added in small groups.
    Português - Programação Moderator Filipe Francisco's Avatar
    2001-12
    * PORTUGAL * Sintra *
    859
    I simply load mine lisp rotines when i need them...
    "appload" and save them in "Startup Suite"
    Cheers,
    2005-08
    1,043
    I have custom menus (.mns, .cui, .mnl) which I use to load all my lisp routines. I have two. One loads all the shared subs, and one loads all the lisp files with (autoload ...... The .mnl files are the ones used to load the lisps and subs.
  1. LISP routines
    By dawn.pedersen309807 in forum AutoLISP
    Last Post: 2012-08-28, 07:36 PM
  2. how do you call other lisp routines with lisp?
    By moises.y969653 in forum AutoLISP
    Last Post: 2011-02-06, 01:01 PM
  3. Lisp Routines
    By Shadrak in forum AutoCAD Customization
    Last Post: 2009-10-08, 01:32 AM
  4. Lisp Routines
    By jsnow in forum AutoCAD General
    Last Post: 2009-04-16, 05:07 AM
